Will Tire Pressure Sensors (TPS) from a G35 work on the Z?
I have an 2005 Z which has tire pressure monitoring standard. I need to get an extra set of sensors for my new wheels. I have an oppurtunity to buy some sensors from the owner of a 2004.5 G-coupe. Will the TPS from the G35 work? I thought the G35 did not have the same tire pressure monitoring system (i.e., the G35 does not have the ability to relay specific tire information).
Yes, that'll work as they are indeed identical parts.
If however you're thinking of using two full set of tires with TPS that will not fly. Each sensor has an unique ID which must be registered into the on-board system and it has provision for only 4 sensors (1 full set) at one time. So, by registered the new set to the system ... it'd drop the previous 4.
BTW ... it is possible that specialP actually picked up someone else's TPS. These are non-critical and low-security items, which would mean only so many unique IDs are employed. My guess is 256 variations (simple 8-bit).
Vigman
Nov 17, 2015 04:34 AM
