Wheels Tires Wheels, Tires
235/30/20 and 265/30/20 Tires (or 245/275)
Old Feb 2, 2012 | 07:13 PM
parhamm1's Avatar
parhamm1
Default 235/30/20 and 265/30/20 Tires (or 245/275)
I need some tires! Either close to new or new. Need two of each. Will also consider 245/30/20 and 275/30/20. No real preference on type as long as I can flip them after some camber wear.
I'd pick up or need them shipped to 28078.
Old Feb 3, 2012 | 09:58 AM
TripleD's Avatar
TripleD
You don't want a 235/30/20, I promise you! Not if you care about your rims. That is like no protection at all. I am running 255/30/20 and I am just asking for it. I would highly recommend 235/35 if you are going to go that narrow in the front. I run Toyo Proxes 4, they are an awesome tire for the money. I got 45K miles out of mine with a bit of negative camber.
Check out www.tiresdirect.net, they have that size you want for $172 a piece. You could then do a 295/30/20 in rear. You won't find much cheaper than tiresdirect.net, as log as you don't live in Illinois you also avoid sales tax. You might also want to check out treadepot.com, I have done a ton of tire research and looking around, you probably won't beat one of these two places.
Also may look at General Exclaim UHP, I have been told they are excellent for the price.
Old Feb 3, 2012 | 10:17 AM
parhamm1's Avatar
parhamm1
^I agree with you 100%. My only issue is low offset. I won't be able to fit larger tires.
235 is probably too skinny tho.... I need 245/275's.
Old Feb 3, 2012 | 11:35 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Probably doesn't help because they are 245/35 but the price is right:
http://eastnc.craigslist.org/pts/2828387334.html
Old Feb 3, 2012 | 11:53 AM
parhamm1's Avatar
parhamm1
I wish.... Wrong size for me tho.
Old Feb 4, 2012 | 10:54 AM
Jose2008Z's Avatar
Jose2008Z
What are the wheel specs? I am running 20x10.5 all the way around +15 front +0 rear...235/35 for the front would be perfect. I'm running 245/35 all around and wish I had done 235/35 in the front. I rub at full lock. Just my
Old Feb 10, 2012 | 04:45 AM
TripleD's Avatar
TripleD
Please post your wheel specs. You would be amazed at how much tire you can put under those fenders. At first I was running a 255/35/20 up front, for about 5 miles, lol. It rubbed just the tiniest bit on the inner fender liner, and only when hitting a bump and turning at the same time, like pulling into a gas station or something like that.
Old Feb 10, 2012 | 09:52 AM
P Casey's Avatar
P Casey
go 235/35 and 265/30 general uhp. Falken 245/30 and 275/30 have good stretch which make them good for lower offsets. If you wanna spend monye go with toyo 245/30 and 265/30... tires easy has good deals on rear generals for 82 bux a piece.
ablaine
Nov 29, 2016 10:13 AM
