Sponsored by:
Sponsored by:
Boned by dealer?
Old 04-09-2015, 07:52 AM
trailrider098
trailrider098's Avatar
Default Boned by dealer?
This past Sunday I'm driving my 03' 350 track package(stock wheels, brembo brakes, suspension is just koni struts, no engine mods), I'm getting on the throttle a bit and it cuts back like traction control came on with slip. It happened again the next time I opened it up but it cut then went back to WOT. I thought it was funny so I shut the car off and tried WOT again, this time I had nothing past 50% throttle. Looked up stuff online and here and other guys say they've had problems with TPS saying it won't throw codes or a CEL when it goes bad. Also when it goes bad the cruise control won't set, I also have that.
So sounds like TPS... Well I drop it at the dealer monday morning cause I'm working 14hour days this week and stress that I need the car back for Friday. They didn't put it on a lift till last night and now call to say they are 4 hours into a diagnosis and still can't find the problem.
Do I go pull the car outta there and start swapping on new parts myself or let them keep racking up a bill? I'm supposed to be racing it Saturday, stock class track day and then doing first AutoX of the season Sunday.
Old 04-09-2015, 07:55 AM
trailrider098
More info. Yes, tire size is not stock. I read up on the traction control not liking certain staggered size tires and front to rear circumference needs to be 1-3% smaller and my current setup sits at 1.8%. And to double check I put on stock size tires/wheels and still experienced only half throttle.
Old 04-09-2015, 08:46 AM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
I would check the tail light bulbs. You could be experiencing throttle cut from a faulty bulb.
No trolling , google it if you don't believe
Old 04-09-2015, 09:14 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
You didn't mention whether the dealer found any trouble codes when the scanned your ECM? That should be the starting point. And I wouldn't say you're getting boned by anybody- after all, you brought the car into them with a problem and said 'fix it'. Also, not sure what you mean by TPS (tire pressure sensor)?
Old 04-09-2015, 09:23 AM
StuLax18
General & Tech Moderator
StuLax18's Avatar
Received 3,339 Likes on 2,379 Posts
Throttle position sensor was my best guess.
Old 04-09-2015, 09:58 AM
trailrider098
Well good guesses guys. I actually did check tail lights, no codes and no CEL
The dealer found that the vehicle dynamic control module has gone bad. They were listed as $1050 from nissan however they are no longer stocked and no dealer in the country has one.
Now what?
Old 04-09-2015, 10:02 AM
jhc
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Salvage yard w low miles
Old 04-09-2015, 10:19 AM
bith8791
bith8791's Avatar
What jhc said, I really find it hard to believe nobody has one though, you should be able to find one somewhere.
Old 04-09-2015, 02:23 PM
slow7
slow7's Avatar
https://my350z.com/forum/engine-and-...trol-safe.html
just an opinion but hope this works buddy hate to see a Z on a junkyard
Old 04-09-2015, 05:07 PM
trailrider098
Well i learned that the module i need only came on 03' and 04' models with the dynamic traction control. I ended up finding a wrecker who had the part for $150. It's a small aluminum box that bolts to the bottom of the steering column near your feet. One wire (pink w/blue stripe) was sending a random 5 volts to the ecu making the car think the brake lights are on reducing throttle.*
*according to the dealer
Old 04-09-2015, 05:11 PM
dkmura
dkmura's Avatar
OK- let us know how your DIY install goes and if it's successful. This is the first failure like this I've heard of...
Old 04-09-2015, 05:14 PM
trailrider098
Slow7, very good info in that thread. Thanks
Old 04-09-2015, 05:23 PM
slow7
slow7's Avatar
no problem let us know what happens
Old 04-10-2015, 12:49 PM
trailrider098
So I took the car home from the dealer, they pulled the pin outta the connector for that pink/blue wire causing the problem. It just means all the traction lights and abs is off till I fix everything myself.
Well here is the new VDC module the dealer says went bad. I replaced it, then started looking for the pin they pulled out of the connector and found this...
Well after flipping out because they cut the wiring harness open I took the car for a drive and I'm back to the original problem!!! I'm better off opening that wire back up and doing my track day tomorrow with no traction control or abs
Old 04-10-2015, 12:56 PM
iideadeyeii
iideadeyeii's Avatar
They cut your harness without your permission? WTF tell them they're buying you a new one
Old 04-10-2015, 01:40 PM
monztr
monztr's Avatar
They had permission to service the vehicle. Even if that means cutting a harness.
Old 04-11-2015, 03:00 AM
trailrider098
Well I fixed the car myself and you guys won't believe what it was. The dealer diagnosed the problem as a brake input fault in the VDC module, it was sending 5 volts to the ecu on that pink wire they cut telling it to cut throttle. And they were correct... However the module was working 100% and that's where they were wrong cause there's a reason for the module to have the bad signal.
Last Saturday the new led taillights I ordered as a quick replacement for my leaky, water filled stock bulb ones came in and I put them on. Sunday afternoon I noticed the problem started. Well as it turns out the LED bulbs complete the circut even when not lit making the computer think that the brake lights were on and purposely cut throttle.
Cost of eBay LED tail lights $125, 4 hour diagnosis from dealer $436, the new VDC module from a JY $150. For a total of $711 all because of a cheap set of china lights that prob need an extra resistor so the circut matches the stock bulb resistance. And yes, I was amazed when I swapped taillights 4 times and got the bad results each time with LEDs and good with stock bulbs.
http://m.ebay.com/itm/281477851522?txnId=1353921863018
Old 04-11-2015, 07:18 AM
bith8791
bith8791's Avatar
Lesson learned, don't buy cheap **** off of eBay ladies and gentlemen.
I'm glad you got your z back to normal.
Old 04-11-2015, 07:46 AM
terrasmak's Avatar
Do not buy!!
Basically post #3 but I didn't know you just installed ebay taillights
Old 04-11-2015, 08:52 AM
jhc
jhc's Avatar
Wow, glad you got it sorted after the time and $$$. Makes you wonder tho why engineers chose the tails for the signal rather than the brake pedal switch itself.
Quick Reply: Boned by dealer?
