Aftermarket Radio Not Powering On - Help
While driving to work a day or two ago my radio just suddenly turned off. It will now not turn back on. (at start or when I hold the power button).
It is a Kenwood double din unit.
Any knowledge you could pass my way would be greatly appreciated.
Please title your threads according to your content, unless you are stuck in a well titling it "HELP" will get you nowhere
That being said you should check your wiring, most likely something came undone like your Remote wire for instance or your main harness in the back
