370Z Brakes & Suspension 370Z stoppers, coils, shocks/dampers
will 350z bbk fit on 370z?
Old 06-08-2009, 04:52 PM
ssc
ssc's Avatar
Default will 350z bbk fit on 370z?
just a quick question...will a big brake kit off 350z fit on 370z?
Old 06-08-2009, 05:04 PM
cdoxp800
cdoxp800's Avatar
No. It's a different bolt pattern. Why not Just get the 370Z Akebono 14" Big Brake Kit
http://conceptzperformance.com/Cart/...173.21.127.203
Old 06-08-2009, 05:06 PM
KS0385
KS0385's Avatar
Perhaps he wants to use the ones he already has?
Old 06-08-2009, 05:09 PM
cdoxp800
cdoxp800's Avatar
Well in that case, I am sure you could make a bracket that would work then.
Old 06-08-2009, 05:12 PM
ssc
ssc's Avatar
yup i used to have 350z... just weighing my options
Old 06-18-2009, 09:37 AM
blueper4mancez
blueper4mancez's Avatar
i think the rear will bolt right up . since the stock rear akebonos bolted right up to the 350z.
Old 04-18-2010, 08:13 PM
trinityracer
trinityracer's Avatar
I have a StopTech front/rear kit for my 350Z and called StopTech to see if it would fit on the 370Z. They told me its a direct bolt on for the Base/Non Sport Model and for the Sport Model I would need new brackets and rotor hats.
Old 04-21-2010, 12:25 PM
bluz370
bluz370's Avatar
I am confused.. See if you can follow me.
The Akebonos on the Sport 370z are a direct bolt on for the non-sport 370z.
The akebonos need a different bracket to be installed on a 350z.
If the akebonos Do not need a bracket to install on the Non-sport 370z, this would mean that the 350z brake kit will not fit.
anyone else follow what I am saying? If I dont make sense, correct me.. as this would be cost effective for me to possibly buy a 350z brake kit for my 370z non sport.
Old 10-29-2010, 08:23 AM
TheDangerZone
TheDangerZone's Avatar
I kind of understand.... but not really. lol
Old 11-28-2010, 05:43 PM
BoomerZ33
BoomerZ33's Avatar
uhhhh hmmm i guess the answer is no. you can go from 370 to 350 but not vice versa
Old 11-28-2010, 10:16 PM
lgear080
lgear080's Avatar
i find this very interesting. can we have someone confirm front bracket on non sport 370z is same as 350z?
Old 12-08-2010, 10:23 PM
bbs350z
bbs350z's Avatar
370/g37 or any new nissan/infiniti akebonos will need a bracket to work on the 350/g35 setup. this has been proven
Old 12-09-2010, 07:47 AM
lgear080
lgear080's Avatar
^ that is not what i am asking... i am asking if non-sport 370z brake mount points are
the same as 350z brake mount points (which are identical from '03-'08). for that we'd
need a 370z non-sport owner to confirm...
Old 12-10-2010, 11:59 AM
Chris_B
Chris_B's Avatar
The uprights on the 370Z Sport and 370Z non-Sport are the same as far as brake mounting points go. The 350Z is different in the front.
The OP didn't say which BBK he was looking at, but as far as AP Racing goes:
Moving the front 6-piston 350Z kit over to the 370Z will require new hats, brackets and brake lines.
The rear 4-piston 350Z kit is a direct bolt-on to the 370Z IF the caliper brackets were made after September 2007. Earlier brackets will need some light milling or heavy grinding due to a clearance issue. All other components are interchangeable.
Old 12-12-2010, 06:03 PM
To get big brakes for a 370Z I recommend that you begin with a 370Z. Sure go ahead. Call me crazy.
Old 03-26-2013, 09:40 AM
MonkeyMagic72
MonkeyMagic72's Avatar
The Akebonos 350Z bbk should fit on the Non-sport 370Z, because the Akebonos was original design for the 370Z. If that does make any sense? To fit the 350Z kit on the 370Z, just bolt it right up without using the 350Z custom brackets. I don't know how you would save money to buy the 350Z bbk for the 370Z, because it would be cost more, due to extra custom parts like the brackets and bolts. I would just buy the 370Z Akebonos bbk because it is cheaper without the custom non needed brackets. I hope this would help.
http://www.conceptzperformance.com/C...398.193.80.110
Old 11-18-2013, 01:46 PM
Doriftomodachi
Doriftomodachi's Avatar
I have a 370z touring which does not have the Akebonos. The Akebonos are a direct bolt on to my car. Akebonos do NOT fit on 350z without a bracket.
He answered your question. Why on earth would Nissan make 2 different size brackets for the 370z sport and non sport packages?? That's just stupid because it's not cost effective
Old 06-09-2014, 03:03 PM
need 4 speed
Vendor - Former Vendor
need 4 speed's Avatar
It all depends, just make sure that the brake kit you have has the same bolt pattern on what you install it on. And it wont ever hurt calling the manufacturer to double check.
10-04-2015 07:55 PM
_koubie_
09-20-2015 06:34 PM
Quick Reply: will 350z bbk fit on 370z?
