VQ35/37 Flywheel interchangeable?
I dont think there interchangeable, but I have a ACT Streetlite flywheel from my 03 Z, still brand new. I sold the Z and I now own a G37S. The clutch slips badly from 2-3 so Im going to swap it out.
Long story short I'm wanting to know if the flywheels are interchangeable. If so that would definitely save me $400 from buying another LW flywheel.
Also, I had the JWT setup in my Z, great clutch but had a ton of chatter in the lower RPMs, it sounded like marbles being rolled around inside a metal can.
Since I have a G37 now I'd like to keep it as quiet as possible, but I want to get rid of the heavy dual mass flywheel. Is there any clutch and flywheel combo's that are quieter than the JWT setup?
I looked at some places it s the same , I checked with ACT applications for both models & it says different p/n s . I would double check on your end mate to make sure on flywheel .
Would you have some place or someone to make a side by side compare !
Always doublecheck mate .
on
I thought that they had the little line dots things on the flywheel for a sensor where in different spots. That if you used the wrong one it'd throw a cel or throw your car into limp mode....something like that. I could be way wrong though
on
I found this on another site
also a de flywheel will not allow a hr to start since theres a different crankshaft positioning sensor wheel on it, clutch itself MIGHT work but impossible to know without knowing spline count and offset from the transmission face only experimentation will tell.
on
I just googled "de flywheel on hr" then it was in nico club. That's a lot of trial and error! Being off by just a spline. I guess if you got it wrong a person would get really good at installing a clutch and flywheel.
