battery's
Old 07-29-2014, 05:22 AM
92K1500
92K1500's Avatar
Originally Posted by chaseAD21
other problems such as? Cuz thats the voltage the battery puts out no matter what the charge on it is the only reason its usually up around 15 is because of the alternator. The only problem I think I have right now related to that is the battery is ****ing old!!! But for me right now charging it every week back up to 100% in 10 minutes is fine with me I have other things my Z is sucking money out of my pocket for, you know
With the car running you shouldn't be getting that much voltage drop. You also shouldn't have to charge the battery every week unless you drive 3 miles a day and listen to the radio with the car off in between.
Also, a lower amperage longer charge is better for your battery than a 10 minute high amp charge.
Old 07-29-2014, 08:33 AM
chaseAD21
chaseAD21's Avatar
Lemme add that it only hits the 12.3v range occasionally when at idle and the A/C is on high, hids on, amp on and pushing the sub hard
Old 07-29-2014, 08:38 AM
chaseAD21
chaseAD21's Avatar
yea I drive more than that one way, but I do use it when the car is off. And ➕1 to trickle charging thats a no brainer. But for the sake of argument I was just saying it can be a simple and quick stop gap
Old 07-29-2014, 03:23 PM
shadowm891
shadowm891's Avatar
well haven't done the big 3 upgrade to my car yet which i know i need to get done soon. i look under my hood today to see if i can find my alternator which i did. from the looks of it from where i was facing it don't look to hard to do. would i need to remove my alternator to do the power wire or should i be able just jack my car up and replace it with it bolted up ?
lapham3
10-07-2022 03:15 PM
Rev_Night
11-07-2020 06:00 PM
OdesiTT
09-30-2015 10:47 AM
Shane86
09-17-2015 05:33 PM
Quick Reply: battery's
