S2K Engine Start Button install write-up
Old 10-25-2006, 05:31 AM
  #61
TurboSteve
TurboSteve's Avatar
turn the key off like normal
Old 10-25-2006, 06:24 AM
  #62
MustGoFastR
MustGoFastR's Avatar
Operation of button:
To start the car, depress clutch, insert the key, turn it to the "on" position, position III, (position I being "OFF", II being ACC, III Being "ON, IV being "Start"), then hit the button to start the car instead of turning the key to the start position. To turn off the car, simply turn the key as usual. This is exactly how it works in the S2k (or Ferrari Enzo and many other exotics, for that matter).
Old 10-26-2006, 06:22 AM
  #63
TurboSteve
TurboSteve's Avatar
i got my button in the mail last night and installed into the console, so I'll be wiring it up tonite.
My quick question is: do I need to unplug the battery for this or is this a safe install with the the battery still connected?
Old 10-26-2006, 08:38 AM
  #64
THE TECH
THE TECH's Avatar
You don't need to unplug the battery.
Old 10-27-2006, 09:43 AM
  #65
usmanasif
usmanasif's Avatar
Originally Posted by mahont
+1 ... any ideas?
Nothing concrete as yet. Those with a single DIN HU can fabricate a simple cover for the available DIN pocket and install the push start there. Also, there is one spot available by the heated seat controls, but since that is rectangular and the button is round, I don't know how nice it will look. Besides, I want it to be up front anyway so it faces the driver's seat.
Old 10-29-2006, 08:37 AM
  #66
TurboSteve
TurboSteve's Avatar
new gauges as well
Old 10-31-2006, 10:56 AM
  #67
MustGoFastR
Originally Posted by Voboy
http://www.nissanusa.com/altima07/
Maybe well be able to get our hands on this start button coming soon on the 07 altima. Looks good to me.
Interesting. Maybe the '07 Z will come with one as well.
Old 10-31-2006, 04:22 PM
  #68
xNeo
xNeo's Avatar
I don't think a start/stop button is all that useful, but it sure as hell is cool! I hope they have them in the new Z.
Old 11-05-2006, 01:47 AM
  #69
usmanasif
usmanasif's Avatar
Originally Posted by GTNPU Z
Well, if the red S2K button doesn't float your boat, you can always try to integrate the ones found on Lexus:
The issue with that one is that it is a part of the Intelligent Key system (as is the '07 Altima's) whereby the ECU senses the proximity of the key fob (and the RFID transmitter in it) and upon validity, a simple push of the button starts the car; i.e. there is no key hole. I don't know if it can be integrated into a non-RFID ignition system.
Old 11-05-2006, 06:07 AM
  #70
THE TECH
THE TECH's Avatar
That one has already been discussed. Due to its complexity and super high cost, there is really no vailidity in trying to make something like that work.
Old 11-06-2006, 10:50 AM
  #71
Ztalker
Ztalker's Avatar
Originally Posted by TurboSteve
new gauges as well
sweet....very cool
could someone post pics of the actual connections between the two red relay wires from the start button and the oem ignition wires(black/red and white/red)?
Old 11-06-2006, 12:21 PM
  #72
MustGoFastR
Originally Posted by Ztalker
could someone post pics of the actually connections between the two red relay wires from the start button and the oem ignition wires(black/red and white/red)?
All of that is detailed in post #2 of this thread. The pics may not show exactly what you are looking for, but with the way I wrote up the connection options, it's hard to mess it up; the wires are easy to identify.
Old 11-06-2006, 03:30 PM
  #73
Ztalker
Ztalker's Avatar
i have no problem installing the start button, the relay and the black grounding wire, but sorry i'm totally lost when it comes to the actual hot wiring to the harness.
Old 11-06-2006, 05:35 PM
  #74
MustGoFastR
The two red wires from the relay connect as follows:
The wire coming from pin 87 of the relay will tap the black/red ignition wire at pin 3 of the ignition harness. Just strip a section of the wire and solder the wire from the relay to this point, then tape it up.
The wire from pin 30 of the relay is the starter wire. This connects to the white/red wire at pin 4 of the ignition harness in one of three ways: You can either:
A. tap the wire like you did the other one (this allows the car to start with either the key or the button).
B. Cut the wire and make the connection on the starter side and tape up the cut end leading to the connector. (this disables the key from starting the car and makes the button the only way to start it).
C. Cut the wire and wire it as in choice B, while also adding a wired two position (on/off) interrupt switch between the cut ends of the starter wire. This allows you to choose to disable/enable the key's ability to start the car at the flick of a switch. You will solder two wires to the cut end of the white/red wire leading to the starter: one red wire from pin 30 of the relay and one from the interrupt switch. The other wire from the interrupt swith will connect to the cut end of the white/red wire going into the connector.
I really don't know any way to explain it more clearly...
Old 11-06-2006, 07:41 PM
  #75
Ztalker
Ztalker's Avatar
^thanks for taking the time again and explain to an idiot like me...i really appreciate it. If only i could see a picture of the soldered wires ...a picture is worth a thousand words i guess. So the (pin 30) wire is soldered to both the red/white wires and the (pin 87) wire is soldered to both black/white wires at the harness all together.
Old 11-09-2006, 07:05 AM
  #76
MustGoFastR
Umm... What BOTH wires are you talking about? There is only one black/red wire and one white/red wire (read Black wire with red stripe, white wire with red stripe) at the harness and the wires from the relay only connect in one place.
These ar ethe two wires you use at the connector:
For the pin 87 wire going to the black/red wire, you don't cut the black red wire into two; you just strip off some of the insulation and solder the pin 87 wire from the relay to that point. You kind of make a "T" with the wires.
For the pin 30 wire from the relay going to the white/red wire, it depends on how you wnat it hooked up as to whether you cut it or not; the various ways are described above. However you do it, though, the pin 30 wire from the relay only connects at one point. You can tap like the pin 87 wire or you can cut the white/red wire and connect the pin 30 wire to the cut end going frther into the car (to the starter), not the connector.
I'd take a pic if I could, but that would require alot of disassembly and unwrapping of wires, etc.
In the picture below, the red wire ruinning into the loom is the pin 87 wire that is tapping into the black/red wire. Behind that, you see the cut end of the white/red wire running to the starter with the red pin 30 wire connected to it. The blue wire also connected there is from the optional switch. Right behind the connector, you see the other blue wire from the switch taped up; it is connected to the cut end of the white/red wire going into the connector. If you don't want the switch, just omit those blue wires from the pic and you have the setup for button start and disabled key start. If you want to start with either key or button with no switch, you don't cut the white/red wire at all; you tap it like the other one.
Old 11-09-2006, 06:25 PM
  #77
leemik
leemik's Avatar
w00t! thanks for the great DIY man!
Here's my button with the Evo-R carbon fiber dash kit..
1. planning it out.. I just did the lazyman approach and traced the top of button itself Lots of maskng tape to make sure i don't crack the carbon fiber..
2. Not the neatest hole but a very snug fit and it's all covered up anyways
3. I wrapped the top of my button with black electrical tape so it's not shiny.. It makes the gap not appear as bad IMHO.. it's being held in the back with epoxy glue and 3M tape.. sucker is not moving lol
4. Mine must have been installed a tad bit lower because I didn't have to dremel that plastic support to make it fit!
5. Taaadaaa finished!
--mike
Old 11-09-2006, 06:28 PM
  #78
leemik
leemik's Avatar
This is bad information.. Please unplug the battery .. a friend of mine did his this week on his G35 and ***SPARK****!!!.. he needed to buy a new $20 main fuse from the dealer..
--mike
Old 11-09-2006, 10:01 PM
  #79
JDMFairlady21
JDMFairlady21's Avatar
as always, very good info and write up leemik!
Old 11-10-2006, 08:18 AM
  #80
MustGoFastR
--mike
Hmm, that sucks. He must have crossed some wires or grounded something he shouldn't have or turned something on while working on it or something... I'll add a note to the write-up.
Quick Reply: S2K Engine Start Button install write-up
