DIY- Add paddle shifters to any Nissan/Infiniti
Old 02-11-2008, 08:34 AM
turbocad6
turbocad6's Avatar
Default DIY- Add paddle shifters to any Nissan/Infiniti
hey guys, new to this forum. I guess once you buy a VQ powered car, there are several forums that are a big help for these car's & even though I have an FX I have been able to find valuable info here that still applies to my vehicle, soooo, here I am
I have wrote a guide for installing paddle shifters on any nissan/infiniti, including the Z's, G's & the FX's, as well as the M's... thought this might be something some of you guys here may be interested in, so here is a link to the guide I wrote : http://www.infinitiscene.com/forum/s...ead.php?t=1369
if anyone has any questions or anything you can post them up here & I would try to assist as much as I can... I have not done a Z yet, but I'm sure it could be done, just a matter of determining the mounting of the paddles themselves, also, while the wiring may be very similar, there is a good chance that the color codes & maybe even terminal #'s will be diferent, I am trying to collect the wiring for other cars too, so if anyone has a diagram of the shifting from the manual for a Z I would apreciate it, so I can add that to the guide as well
Old 02-11-2008, 12:30 PM
nismo*son
nismo*son's Avatar
nice write up
Old 02-11-2008, 12:33 PM
Klei14
Klei14's Avatar
Thats alot of custom work!
I will wait for the price on the kit that Zackt69 on G35driver is making!
His will be "bolt on"
Old 02-12-2008, 12:52 PM
turbocad6
turbocad6's Avatar
yeah, zacks kit wil be cool & much easier, but if a kit is not available then this is still an option... wish there was a bolt in kit when I built mine, some cars theres no chance of a bolt in kit though
Old 02-13-2008, 11:18 PM
Racer_X
Racer_X's Avatar
fantastic write up my man... great pics and details... thats a top notch DIY
Old 02-25-2008, 09:05 PM
gregom
gregom's Avatar
That is freaking sweet!!! I wish I had the confidence to do it, I hate using the shifter, and i'm very used to paddle shifters playing racing games with a wheel.
Old 02-25-2008, 10:06 PM
350ZTheStandard
350ZTheStandard's Avatar
Damn this is sooo amazing, I am waiting for more info on how to do this on the Z car. Thanks for the kick a$$ write up.
Old 02-25-2008, 10:07 PM
Willie
Willie's Avatar
Thanks for sharing.
Old 02-26-2008, 10:35 AM
turbocad6
turbocad6's Avatar
hey guys thanks, I'm really glad to be able to share this with you all. I have a body shop in bay ridge brooklyn & if there are any local G's or Z's that would consider this paddle shifter upgrade I'd be happy to work with someone local to see how the mounts could be developed for you guys...
Old 02-26-2008, 04:52 PM
aloh
aloh's Avatar
Is its response time for up/downshifts the same as if you used the shiftknob in manual mode?
I like how it looks really OEM. If i get more info on how to do it for a 350z, id be tempted to try it myself. Do you think you oculd get your hands on a Z to do a writeup on?
Old 02-27-2008, 06:26 AM
james840a
james840a's Avatar
i Have to say, nice write up even tho its not for the 350z
But im still going with, that its not going to fit on the 350z.
if you look at how deep the switch is in your photo left side, its still to deep to be mounted on the right side even with your modification on the back of the switch, as i said in my post under interior/exterior section the 350z IGN. key switch is like right behind the wipe control on the column shaft
here is a picture from your DIY of that im talking about. The in red square is were you have the paddle switch located, the yellow circle is approxemently were the key switch is on the right side
Old 02-27-2008, 11:17 AM
turbocad6
turbocad6's Avatar
aloh, the response time is exactly the same as the shifter handle... technically it's probably a few ms quicker because there is less travel time of the activation itself compared to the shifter, but realisticly it's the same.
james, do you have any pictures of your ign switch location? if anyone could get some good close up shots it would maybe help, if anyone was willing to drop there cover it might help even more....
Old 02-27-2008, 01:57 PM
aloh
aloh's Avatar
I took some pics just to help out.
The right side where the ignition is does seem a little small. Do you think it owuld be an issue?
Old 02-27-2008, 02:14 PM
james840a
james840a's Avatar
^second picture above is a good one of key location on the 350z
Old 02-27-2008, 05:18 PM
Oleg
Oleg's Avatar
PM sent...
Old 02-28-2008, 07:35 AM
turbocad6
turbocad6's Avatar
woh, that does look tight... nothing is impossible though, worse case might be that the right paddle needs to be modified... it's just a mechanical lever with a micro switch, so with enough effort I'm sure it could still be done.
oleg has expressed interest in exploring this possibility with his Z, I will try to get with him next week & see what could be done. the ign switch does look like an obstacle, but not necessarily something that couldn't be worked around, I'm sure there is a way, just depends what would be involved.... well see
Old 02-28-2008, 08:30 AM
james840a
james840a's Avatar
^ your right, nothing is impossible.
Just have to rebuilding the switch unit to make it smaller. Makes it pretty much harder to todo then most everyone is thinking. But ill let you work on it. Im going with my design, i just have to finish the switch housing. I got my levels and switch unit built and didnt cost me much of anything but time.
Keep up with the good work tho
Old 02-28-2008, 10:55 AM
Oleg
Oleg's Avatar
We'll get in touch early next week and procede from there. I'm really looking forward to seeing how this comes together...
Old 03-11-2008, 07:48 PM
Oleg
Oleg's Avatar
OK, guys, whoever was keeping their eye on this, here is an update. The left one fits with no problems. The right hand one cannot clear the ignition switch without additional modifications to the shifter.
Hopefully John will chyme in with additional info.
I will most likely go through with this, so stay tuned for more info and pics.
Old 03-11-2008, 09:42 PM
aloh
aloh's Avatar
Hm well what i relaly like about this kit is that it uses the OEM paddles from the G35's.
I hope John finds a solution to it.
Quick Reply: DIY- Add paddle shifters to any Nissan/Infiniti
