Body Interior Seats, shift knobs, etc.
STACK Gauges and Displays at MA Motorsports -BEST GAUGE ON THE MARKET-
Old 07-31-2015, 09:46 AM
MA-Motorsports
Vendor - Former Vendor
MA-Motorsports's Avatar
Default STACK Gauges and Displays at MA Motorsports -BEST GAUGE ON THE MARKET-
We here at MA Motorsports not only sell STACK, we are also Technical Agents for the products. That means that we can get you the product, AND have the knowledge to help you with issues. We are truly a one stop shop for all your needs.
For over 30 years Stack has been the leading provider of Motorsport dashboard and data logging technology. Stack's range of gauges is designed for the maximum in reliability, robustness and quality. Stack gauges are rugged, transistorised instruments with solid-state circuitry.
The superior build-quality and advanced engineering offer perfect digital quartz accuracy maintained for life. The units are well sealed against water and dust to IP67 and are proven performers in the demanding environment of Motorsport.
Stack’s unique stepper motor movements delivers competition performance with absolutely no needle waver.
Throughout the range, classic no-nonsense styling is combined with the very latest technology - form, functionality, reliability.
“Independent aerospace industry studies confirm that an analogue needle is the best solution for displaying fast changing information such as engine speed!
Pro-Control Gauges
Stack’s Pro-Control range of Professional Stepper Motor Analogue Gauges brings total control and driver awareness of critical engine functions.
The Pro-Control series has all of the features of the Professional Analogue Gauges plus:
o Peak “tell-tale” Memory - Max temps, Min pressures
o Configurable max and min full dial alarm warnings
o Configurable Pro-Control output for activating accessories eg. fans, pumps, etc (requires relay)
o Temperature gauges with built-in “fan controller”
o Pressure gauges with built-in “pump controller”
o 0-5 Volt analogue output for data logger or ECU (except EGT and Fuel Level gauges)
o Configurable backlight colour
o Black dialface when powered off
Key Features:
o 52mm diameter
o Fast, smooth stepper motor needle drive
o 270° full sweep movement for excellent readability
o Remotely mounted solid-state sensors keep hazardous fluids in the engine compartment
o Better than 2% accuracy
o All-electronic design for maximum reliability
o 7 Colour LED through-the-dial backlighting
o 7 Colour LED illuminated needle
Gauges Offered:
-Oil Pressure
-Fuel Pressure (Low)
-Fuel Pressure (High)
-Water Temperature
-Oil Temperature
-Boost Pressure
-Exhaust Gas Temperature
-Fuel Level (Programmable)
-Battery Voltage
Specifications
ST3501 Oil Pressure 0-7 bar (M10x1)
ST3502 Oil Pressure 0-100PSI (1/8NPT)
ST3503 Fuel Pressure 0-1 Bar (M10x1)
ST3504 Fuel Pressure 0-15 PSI (1/8NPT)
ST3505 Fuel Pressure 0-7 Bar (M10x1)
ST3506 Fuel Pressure 0-100 PSI (1/8NPT)
ST3507 Water Temperature 40-120°C (1/8NPT)
ST3508 Water Temperature 100-260°F (1/8NPT)
ST3509 Oil Temperature 40-140°C (1/8NPT)
ST3510 Oil Temperature 140-280°F (1/8NPT)
ST3511 Boost Pressure -1.0 to +2.0 Bar (Uni)
ST3512 Boost Pressure -30inHg to +30 PSI (Uni)
ST3513 Exhaust Gas Temp. 0-1100°C (1/8NPT)
ST3514 Exhaust Gas Temp. 0-2000°F (1/8NPT)
ST3515 Fuel Level (programmable)
ST3516 Battery Voltage 8-18 V
STACK Displays
Stack Colour LCD Motorsport Display
The Stack Colour LCD Motorsport Display is the next evolution of driver communication and data acquisition.
The carbon composite housing is IP65 sealed against water and dust intrusion and will easily withstand 20 g of continuous vibration and 50 g of shock.
Our 7" LCD panel ensures easy visibility under all circumstances with unmatched brightness and an optically bonded lens for extreme glare suppression.
The display layout is configurable to your individual specifications.
The system will accommodate two programmable data bus channels (I CAN and I serial) in conjunction with discrete analog sensors and its integrated 3 Axis Accelerometer.
Data collection can occur at up to 1,000 Hz and the internal memory allows for appropriate recording time.
User definable warnings take advantage of super bright, multicolour LEDs placed around the perimeter of the chassis to alert the driver to critical on-screen information.
Display
o 7.0"TFT LCD panel
o Display Brightness: 1000 nit
o Resolution: 800 x 480
o Onboard photo sensors for automatic brightness control.
o 16 User configurable multi-colour LED's
o Display features perfectly rendered virtual analog needles, value display bands, digital value indicators for vehicle parameters and configurable full color text warning messages.
o 20 layers / screens / pages selected from user configurable templates (screens/instrument cluster designs/layouts), additional configurability supporting team selected graphics, parameter / instrument type and location, and size will be made available with future firmware and PC software releases.
Stack ST8130 Street and ST8110SR Street Boost Displays
http://www.stackltd.com/images/Stack_st8100.jpg
Ideal for both Rally and High Performance Street cars, the ST8130 not only retains all the ST8100 racing features but also meets street legal requirements.
Replaces speedometer, tachometer, oil-pressure, water-temperature, fuel-level, voltmeter, oil-temperature odometer and trip meter functions.
Each system is supplied complete with sensors (except fuel level), ready wired harness and manual. Ultra light-weight design utilising a carbon fibre composite housing. Compatible with all conventional & MSD ignition systems and engine types
ST8130 Street Display Features
o Legendary Stack stepper motor analogue tacho display
o Integrates the following display parameters:
o Speed
o Odomoter and Trip
o Oil Pressure
o Oil Temperature
o Water Temperature
o Battery Voltage
o Fuel Level
o Peak Value Recall
o User-programmable Intelligent Alarms
o Separate low fuel indicator lamp
o Waterproof (ideal for roadsters, bikes, and off-road use)
o 1 Year Competition Warranty
o Optional Fuel Pressure channel
o Optional external sequential shift lift
o Optional Lap Timing and Predicted Lap Timing
________________________________________
ST8110SR Street Boost Display Features
This system is specifically designed for turbo charged street vehicles and rally cars.
The system integrates:
o Provides all the features of the ST8130 Displays found above and adds the following features as standard:
o Boost Pressure channel (+/- 0.75 psi, +/- 0.525 BAR)
o Fuel Pressure channel
PM Me or Call me at 410-593-7080 if you have any questions or need prices!
Stack ST700 Display Tachometers
Macro Function. Micro Form.
The ST700 combines the most critical facets of vaunted Stack Race Display into a tidy package, built with the same craftsmanship and attention to detail as the legendary original. With technology derived from decades of Formula experience, the Stack ST700 provides a comprehensive monitoring solution, displaying engine RPM, speed, system voltage, odometer, tripmeter, and acceleration timers (1/4 Mile and 0-60, and user selectable rolling speeds) as standard. An in-built sequential shift life and the ability to enable lap timing and two configurable inputs for either temperature or pressure via optional accessories gives the driver a remarkable amount of information in ever the tightest quarters.
Key Features
4 pattern Sequential Shift light
User configurable analogue channels
Peak Value Tell-Tales on all parameters
Supplied with mounting bracket, switch kit, separate professional wiring
Looms and manual included
Adjustable White LED back-lighting level
Fully sealed against water and dust
1 year competition warranty
For all negative earth ignition systems
Odometer and Trip Meter
Acceleration Timer (1/4 Mile, 0-60, user programmable rolling speeds)
Intelligent Alarm System
Intelligent alarms are provided on all monitored parameters. Alarm levels are adjustable to suit individual requirements.
Configurable Inputs
The ST700 system features two user configurable analogue channels. Each channel can be set up for Water Temperature, Oil Temperature, Air Temperature, Axle Temperature, Gear Temperature, Oil Pressure, Fuel pressure or Boost pressure.
Sensors must be ordered separately, choose between standard and solid state sensor options. These new optional sensors are small, lightweight, provide high accuracy and offer exceptionally reliability.
MA-Motorsports is offline
Old 08-03-2015, 06:03 AM
MA-Motorsports
All PMs replied to!
Old 08-04-2015, 07:02 AM
MA-Motorsports
All PMs replied to!
Old 08-05-2015, 10:48 AM
MA-Motorsports
PM me for the best prices!
Old 08-06-2015, 07:04 AM
MA-Motorsports
New day, same great prices!
Old 08-06-2015, 12:04 PM
MA-Motorsports
All PMs replied to!
Old 08-14-2015, 11:50 AM
MA-Motorsports
Weekend Bump!
Old 08-25-2015, 12:38 PM
MA-Motorsports
All PMs replied to!
Old 08-27-2015, 08:11 AM
MA-Motorsports
All PMs replied to!
Old 08-31-2015, 07:47 AM
MA-Motorsports
Monday Bump! All PMs replied to.
11-09-2020 10:27 AM
Tochigi_236
09-27-2015 03:40 PM
Quick Reply: STACK Gauges and Displays at MA Motorsports -BEST GAUGE ON THE MARKET-
