CZP Brake Lines Suck
^+1, Yeah I thought there was a safety feature that prevents "total" failure. I heard that years ago and it wasn't about Nissans. Complete brake loss suddenly sounds a lot more serious than blowing 1 of 4 lines.
I had Technafit on mine, they could have been an inch longer. Before I put the tire on I cycled the steering and made sure there was no pulling, it took me a few extra minutes to get it right. Stoptech lines also fit the same.
My front lines looked just like the ones 350ZZJoe posted - And I would definitely keep a close eye on those if I were you. . .Mine frayed like that, teflon rubbed away, SS line started to get pulled taught. They are clearly too short to be used in that area. I'll post photos of my Z1 brake lines later, and show how much better they clear everything, and how perfectly routed they are. . .
As far as the complete brake failure after the one line burst, I have no scientific answer for you. In my mind, it could have been that there was just so much fluid loss that there wasn't enough pressure to make the other brakes work properly. Also the master cylinder in the 350Z is no where near powerful enough to handle the larger capacity of the Akebono calipers. There's also a few threads floating around here regarding how the ABS system in the 350Z chassis is not the most compatible when upgrading to the Akebonos, again due to their larger size. So I'm just assuming here, but it's probably a collective result of all these variables.
There is something about the OP’s story I don’t understand. I’ve been told that all brake systems in use over the past 50 or so years have dual circuits in the master cylinder, each one powering two of the four wheel brakes. In the event of a component failure and loss of fluid, the pedal will drop an inch or two (but not to the floor) and still engage two of the four wheels brakes. Usually one front and one rear in a diagonal fashion.
Why did the loss of only one line cause the total loss of all brakes?
It will shut off flow to the side with the leak when pressure is applied. I'm guessing he didn't pump the brakes a few times to get it sealed off.
Also, when going 60 down an off ramp and you lose pressure on your brake pedal I'm sure it feels like you have no brakes left.
I've had a wheel cylinder blow out while sitting at a red light in my old Chevy pickup. I was sitting there and the truck started rolling all of a sudden. I pressed the pedal harder and it stopped, then after a few seconds started rolling again. Again I pressed it harder to stay stopped. Then when it turned green I took off and just tested the brakes and they were hardly there so I pulled off in a parking lot and checked it out.
If he had hit the brakes a couple more times he probably would have regained partial braking. But typical human reaction is panic and he probably didn't think to pump them. They went away once so they are no more.
Administrator
Thanks for the diagram...
Just to keep things out in the open, here is the PM I just sent back to Coz. Out of courtesy and respect to his privacy, I won't post what he sent me directly. But basically it stated that he wish I would have contacted him directly, and that he's happy to reimburse me for the new lines I purchased. Also that he wants his customers to be satisfied, so he wants to make things right.
PM:
"Coz,
Thanks for reaching out; First off I just want to say that I was never trying to bash you directly. You've always been immediately responsive and helpful with my inquires since the beginning. And I even mentioned that you replaced my original rear lines free of charge, in my first post.
I revised my original post to clarify that the brakes lines could have been either your original CZP lines, or the Technafit lines. I'm pretty sure that the fronts lines that were on the car were your original lines that were supplied with your kit. Also, in your for sale thread for the Akebono kit, you have the brake lines listed as "CZP 350Z / 370Z Teflon Coated Stainless Steel Brake Lines." So one would assume that they are made in-house by your shop, or made to your specs, and sold under your name.
While replacing my lines on Saturday night, I originally did set the line aside so that I could send it back to you - not in a request to be reimbursed, but simply to show the danger that could have occurred. I can reach out to the shop where I replaced them, and see if by chance the lines are still sitting in the trash can where I threw them, in which case I'll be happy to send them your way.
I'm not asking for you to reimburse me for the Z1 lines, although I do greatly appreciate the gesture. I have been able to come to you in the past (like my issue with the rear lines), and you helped me out. But I figured that my purchase was so long ago, and what chances would I have with you believing my story that I would get replacements. The way I saw it, I just didn't want to bother hassling you about new lines, nor did I want to have replacements of the same lines that kept failing me. I understand that I'm one of only a few people that might be experiencing this, but I assure you that the lines are/were being installed correctly, bled correctly, and never over-heated or used in track situations.
I'm glad to see that you're all about customer satisfaction, and making things right. But so far, I just haven't seen the quality from the brake lines in the kit that I would have expected for the amount of $$ paid for the kit as a whole.
Regards,
Paul"
PM:
"Coz,
Regards,
Paul"
You're thinking of the combo valve.
My dad used to build complete breaking systems for old hot rods and re-powered vintage cars. He was always sending me all over the place to get 1960s Lincoln, Corvette etc proportioning valves to tune the systems. The valve limits the amount of line pressure to the rear wheels to keep them from skidding on hard stops. The valve you have shown is pretty fancy as it has an electrical circuit that will activate a warning light if there is something amiss.
I have my front StopTech SS lines mounted different than what I am seeing people post here. I can get a photo tomorrow but my routing looks just like the photo shown in this StopTech installation manual for their brake kit. I still have stock Brembo but my routing is the same.
From caliper, bolted to the front side of the upright (flat area parallel to the wheel/tire), then curves around the upright to the hard line connection. There are no sharp bends at all in this routing and mine have been like this since 2010 with no issues.
Page 18 and 19 of this manual. I do not have the black bracket anymore so my mounting method is exactly like what is shown on top right picture of page 19.
http://stoptech.com/docs/installatio...98-646-1450-02
Have you guys using Brembos ever considered using SS lines that replicate the OEM rubber ones installed by Nissan? I am attaching a link to Z1 Motorsports' website. By using the factory design, part of the line bolts to a fixture on the suspension and the second part threads into the brembo without using banjo bolts. It's a lot better setup than home-made brackets or zip ties.
http://www.z1motorsports.com/350_g35...oducts_id=5200
You will not have any problems with rubbing and/or chaffing, something Nissan for liability reasons obviously wanted to avoid.
