350Z Drift Button Detailed Install
Old 04-22-2014, 04:25 PM
Chrlz
Chrlz's Avatar
Default 350Z Drift Button Detailed Install
Hey 350Z community! I have a S13 drift button I am trying to install on my handbrake. I have seen 2 other posts with pictures that show how to install and get it working. The problem is neither of them talk about how to remove the leather hand brake boot. I have tried several times just pulling it off like the guilds suggest but discovered it might still be held on at the bottom (under another plastic boot) or at the top by a small metal collar around the stock button. Here are some pictures after I broke down and took the whole center console off to see if I could figure out what was going on.
I noticed there are some rivets type attachments that hold the lower plastic boot on any ideas on how to get these off?
Thanks for the input! I will try to put together a better guild for any 350Z owners tat would like to do this in the future!
Old 04-23-2014, 06:41 AM
Z33Garage
Z33Garage's Avatar
Maybe you can break them off...
Old 04-27-2014, 08:31 AM
Chrlz
Chrlz's Avatar
I popped them off with a flat head screw driver then took the plastic lower boot off. After that i just pulled up with a slight twisting motion on the leather boot and it along with the button and metal collar came off
I was not able to re use the metal clips (shown in the picture after I popped them off with he screw driver so i used hot glue to make everything stay
Hope I helped some people!
Old 04-27-2014, 08:35 AM
zach711f
zach711f's Avatar
the hand brake sucks monkey ballz for anything other than parking.
Old 04-27-2014, 09:27 AM
KornerCarver
KornerCarver's Avatar
Actually, that is what the hand brake was designed to do and to be used in an emergency if the brakes go out(very unlikely).
Old 04-27-2014, 09:49 AM
zach711f
zach711f's Avatar
I dont care what it was designed for. It works well for parking. locking up your rear wheels for drifting not so much. get urself a hydro ebrake. the hand brake might work for a little bit but it will fail.
Old 04-30-2014, 01:21 AM
samsniss350z
samsniss350z's Avatar
The E-Brake is crap on the 350Z because it operates via a drum brake and tiny little pads. why the hell Nissan went this route god only knows. The only way you're going to get a decent E-Brake to invoke drifting is by removing this drum brake and connect hydraulics to the rear hydraulic callipers.
OperatorAF
09-13-2015 11:36 AM
ILoveDrifting
09-07-2015 03:15 PM
Quick Reply: 350Z Drift Button Detailed Install
