Replace Rear Strut Bushing On The Car? Possible?
Old 03-23-2015, 06:35 AM
digital sol
digital sol's Avatar
Default Replace Rear Strut Bushing On The Car? Possible?
Hello all, I am currently trying to replace my rear strut bushings on my 04g coupe however I am running into some problems. Yes, its a G coupe not a Z but were all the same family
I have to replace the bushings because the bolt was seized to the bushing and it tore right out when removing the bolt. I am replacing my struts with tokico D spec's.
I have some whiteline bushing replacements however I am having a really hard time trying to press the new bushing in. What tool is recommended for the re installation of the bushing? The space is very limited without removing the entire knuckle and I havnt been able to fit the standard bushing press you rent at autozone/oreilly's etc in that area.
I was curious if there was another method that could be used, perhaps a 2 or 3 prong puller setup? I have no experience using the pullers or any other method of pushing bushings besides the standard kit and my 12 ton press.
I had to torch & cut the old bushing sleeves out of the knuckles which was very, very time consuming as is and now I am trying to figure a way to push the new ones in without removing the knuckle. The space is rather limited.
Thanks I really appreciate your help!
Old 03-23-2015, 10:16 AM
RedBullRR
RedBullRR's Avatar
I ran into this same problem as you. First of all getting them out with out the rite tool was a nightmare. The first tool i rented was not a bushing removal tool but ball joint press tool. They look very similar but do not have the same pieces needed, and the c clamp is slightly smaller and just fits with out having to remove the knuckle. I ended up ordering a bushing removal tool from Auto Zone . Pressed them in so smooth made me feel real stupid for trying any other method.
140 from Autozone, and then return it. Literally pressed the new bushings in within 5 minutes each.
http://www.autozone.com/test-scan-an...set/94806_0_0/
Old 03-23-2015, 12:33 PM
digital sol
Thank you so much. I would have never thought about that kit because the one I have looks very, very similar to that. I went ahead & ordered it, thanks!
etkms
06-19-2022 06:30 PM
sales@czp
Suspension
54
01-17-2018 09:24 PM
Suffolk350z
09-13-2015 02:43 PM
ThreeFiveZero Z
09-12-2015 04:33 PM
torchkc
09-11-2015 08:26 PM
Quick Reply: Replace Rear Strut Bushing On The Car? Possible?
