You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What do you guys use as your drift spares? I may pick up some S15 silvia spec-R rims rims as spares but they're only 16x7s...do you think they would still work? If not what are some cheap drift rims i can buy?
lol 16x7's would look straight up goofy on a 350z, especially if you had 18s or 19s in the front.
if youre looking for a cheap decent sized wheel, try checking tire rack for the MB motoring battles. i believe they come in 18x9.5 +15 and +23. so while not amazing for a 350, still not too bad for under 200 a wheel. im going to grab some 17x9.5 +15s for my s13 shortly.
SERIOUSLY240 pointed out what i was gonna suggest........
MB wheels: Discount tire dot com sells them for cheap and with free shipping. Hard to beat for a wheel that can take the abuse.
I would suggest the MB Weapon's and MB Competitions wheels!
offered in 17 x 9 and 18 x 9 sizes with great offsets. either 17 or 15 respectively.
LIGHT WEIGHT:
Another great point is these wheels are LIGHT! yup, they are very light weight and i love my MB's for this when at a drift event, cause changing tires bites! and when your swapping MB's its very very much noticeable how much lighter they are!
On my crappy scale it says my 17x9 +17's are 19-20 lbs. could be off a pound, but they are significantly lighter than stockers, but have the offsets and width needed for drifting.....
OFFSETS: - See first pic.
They sell +17 on their 17x9's
+15 ON their 18x9 wheels.
MB COMPETITIONS - Room for longer studs:
Also, take a good look at the 4th pic - those are MB Competitions.
If you notice, they have holes for longer studs in between the lug nut mounting holes if you need.
The holes are small and you have to drill them out bigger. there is a recession that drills out easy. but as they stand, the holes are not M12 size, so they need to be drilled slightly larger.
Thus those wheels can get mounted with out you having to remove your spacers. Just an option as I have seen some people buy the +27 offset ones and use their 20mm spacers with them at the drift events because they already have the spacers installed.
They roll with stockers with spacers daily kinda thing....... just some FYI...
Also, the "MB Drifter" wheels have this extra hole in between feature as well...they are offered in wider 9.5 inch width too....see last pic...(5th pic)
-J
__________________
04 PPW Touring - My favorite mod is my short Dodge Avenger antenna
i may have to check these rims out. the only reason i was going to get those rims was because a friend of mine were selling them with tires fot $150 for all 4 but i decided to get some real rims
i guess im going to check out the MB rims and some others but my budget would be around $500-$650 :/
Id also like 18s but i think 17s would be easier to slide like you said,
i have a set of the mb weapons wheels and they are great. they are cheap, durable, light, and are easy to replace if damaged. hell i even left them on as my daily driver wheels and i sold my sportmax 006 wheels that were much heavier. i was gonna buy another set of the mb weapons in an 18 and have them coated in gloss black. ill post pics when i get them done.
