engine change
Old Jul 16, 2006 | 08:14 AM
2003G35's Avatar
2003G35
Default engine change
Does anyone know if a 3.5 Altima motor is the same as a 03 g motor as I can get one cheap and send it for complete rebuild (sleves ect ) then just swap motors.
Old Jul 16, 2006 | 08:20 AM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/2003-2009-nissan-350z/203747-350z-and-altima-engine-same.html
Old Jul 16, 2006 | 09:41 AM
gringott's Avatar
gringott
Originally Posted by DavesZ#3
Wow, I was wondering also if it is just an ecu difference, manifold, or whatever, but that thread is exactly ZERO help, it is nothing but bickering and car buying info.
Old Jul 16, 2006 | 10:20 AM
meatbag's Avatar
meatbag
pm trav4011, he would know for sure probly
Old Jul 16, 2006 | 11:12 AM
DavesZ#3's Avatar
DavesZ#3
Yup, but at least it's a thread discussing the same subject. What's the use of a second one asking the same question and getting the same answer (or not)?
Old Jul 20, 2006 | 06:14 PM
nismology1's Avatar
nismology1
That thread is full of misinformation. All Gen II VQ35's (Murano, Altima, Maxima, G35, 350Z, Quest) excluding the rev-up motors are the same internally, down to the cams. The only difference with the RWD motors are external, i.e. mount locations, coolant passages, manifolds, etc.
Don't believe me? Look up the part numbers in the Nissan FAST program and cross-reference yourself.
To the OP, you won't be able to drop in the altima VQ35 since it's in a FWD layout.
Old Jul 24, 2006 | 07:55 PM
2003G35's Avatar
2003G35
Question
Thanks for the info,I can also get an fx motor I know the lower section is differnt do to the axle going there the block but can I swap that part for mine at change time?
Old Jul 24, 2006 | 08:33 PM
nismology1's Avatar
nismology1
That motor should work with no problems.
lapham3
Oct 7, 2022 03:15 PM
