VQ Oil Analysis and Info
Originally Posted by nlsqba
Anybody else using Pennzoil Platinum that has bad experience... I need to change my oil soon and that was my choice...
Will
Originally Posted by TheProfessional
I fell asleep after my last post... I posted my running UOW in my signature.
Our group switched to Amsoil 0W-30 in April, my next UOW should have a contrast against the prior 3 fluid swaps with RP 10w-30 at over 15k mi.
Originally Posted by derek173
Will
Originally Posted by redline350ZZ
The first Post is updated when you get more info? Is there any way to maybe add a F/I list separately from NA list?
Will
Originally Posted by Resolute
Right now, Pennzoil Platinum or Schaeffers looks the best. M1 0W-40 and Amsoil 0W-30 look great too. When you're boosted, So far just M1 0W-40. But, I know one guy is using Eneos in his TT 350Z and will post a UOA on it, plus I'm hoping some of the Motul fanatics will post a UOA on what their using as well. Maybe you'll be the first. I think the new Motul 8100 X series formulations look good.
Will
Will
So where can I locate these oil? Guessing I can't walk into the local Advance Auto and purchase. Gonna need to do a change when I return. Also any recommendations for tranny & diff? GREAT INFO none-the-less. Just wish I understood everything a bit more.
Will
Here is my Mobil 1 0W-40 UOA. This was my first time using this weight, and I put just over 3000 miles of use on it, with two different track events included. The oil did very well, and I'm pleased with it. The results reflected the very low lead wear this oil has in other engines, with below average to average wear results in other metals. If the iron were a few parts per million lower, it would be a perfect performer. The viscosity was very thick still, and it had a high TBN to reflect plenty of life left on the oil for an extended drain application. I wnder if this oil will be as good over a long drain interval as the Amsoil is. The results are very copmparable between the M1 0W-40 and Amsoil's TSO 0W-30, but the TSO has almost twice the mileage on its average results. Although, none of the Amsoil UOA's reported any track time on it, either. So, for longer drain intervals, I still think the Amsoil is a better bet, but for normal drain intervals with track time, the M1 0W-40 is a great choice. Here's the results, and they have been added to the comparison chart for NA VQ35 engines.
Hey Will
Just got a chance to get cought up on the oil UOA reading.
My current M0w40 is at about 2200 mi mark, I will be draining it soon and sending to the blackstone. I will do a TBN this time as it can help you in the analysis. I do have a track day on it as well (much lighter one than the previous Laguna Seca one, though), which kind of throws off the results. The next change will surely NOT include a track day, so that would be best for comparison (we'll know if the shearing was due to the track day or not).
I am growing to relaly like the oil, as I understand it, it's THE oil to be used in turbo cars that you currently recommend, right?
Originally Posted by GurgenPB
Hey Will
Second, I like the M1 0W-40, it's the only Mobil product I would use. I think it might be one of, if not the, best oils to use that can be bought at a local auto parts store. I'm not sure if it is THE best oil to use for FI applications, but surely one of the best. I think your last UOA with the M1 0W-40 looked good for an engine still in it's break-in, and very impressive for one that is running boost at a racetrack. But, there simply isn't enough data to make such a bold claim as the best, and with built engines it's going to be tough to tell just what the best oil is.
Built engines will run different bearings with different bearing clearances, different pistons with different piston to wall clearances, different build and finishing techniques are used, and different turbos, seals, etc... depending on the builder. As such, I think it might be harder to see any real averages from one oil to the next when everyone with a built engine is running a different set-up. The only sure-fire way to see what works is for each owner to run their own used oil analysis log and check for drastic changes.
By comparison, a used oil analysis from stock block VQ35 users is easy to average, since the oil is being asked to perform in an equal setting. The clearances and materials are the same from engine to engine. The only difference is in the driver and additives. The first is not as big an issue as some people think. Look at the results of Amsoil ASL- four seperate engines with different drivers living in different parts of the country, and all had high lead wear. The higher the mileage, the worse it got, with some guy taking his oil to 9k miles showing 40 ppm of lead in the oil. There is a consistancy in that oil to show high lead wear, despite different drivers who probably had very different driving habits. In other words, the folks who track occasionally and/or drive the car "hard" on the street, are not going to see a drastic change in the results over the average unless something breaks. Modern oils are not so sensitive that a track day will alter the wear results more than a few ppm from being consistant with the average for similiar mileage. If it does, then we know it just wasn't that good of an oil anyways. Additives, however, can alter the results drastically, and as such, I can only hope someone who uses an additive fills in the blank asking about any fuel or oil additives used when they submit their oil for testing.
Now, in a built engine UOA, I think the results can vary drastically from one engine to the next using the same oil simply because the engines are built different. I don't know this for a fact, but it is my best logical guess. When there are more FI UOA's submitted, then we'll be able to get some evidence that either supports my notion, or refutes it. If the results do vary from one engine to another in drastic measures, then the best shot we have at coming up with the "best" oil for FI users is to break down the data by engine builder. For example, if GTM uses the same parts and build techniques with every VQ engine they make, then they could very well do a UOA on one of their engines and that oil's results would be pretty indicative of what another user would experience running similiar boost. As such, it would be great to see more companies actually doing this for the built engine/FI guys. This is where your UOA's are so valuable.
I would recommend that you get another UOA done at similar mileage with the M1 and see how much the wear metals have dropped. That will give us an idea of how much closer your engine is to being broken-in. Then, I would try something else and see how that works in comparison for a similar drain interval. i know this makes you kind of a guinea pig, but maybe your builder will run a UOA on one of their engines that is similar. Soon, wear trends will become very apparent. Then, we can look and see if one oil is really doing better than another, or worth the money. I look at Amsoil TSO 0W-30 and see that the wear is higher than the M1 0W-40, but with twice the mileage. If I cut the wear numbers in half to get a fair comparison under equal mileage, then that oil looks very good, but not so good that I would spend the premium and shipping costs over the M1. It's really only better by a very slim margin. I think your engine might be no different, and we'll see some "off the shelf" oils be able to stand as good, or maybe better, to the wear results of the "boutique" oils. My recommendations to try after the M1 0W-40 are the same recommendations I have made to every FI guy who has PM'd me for suggestions:
Shell Rotella T-Syn 5W-40
Eneos 0W-50
Motul 8100 X-Lite 0W-30
Motul 8100 E-Tech 0W-40
Motul 8100 X-Cess 5W-40
Redline 10W-40 (I know it's not very impressive in the stock VQ, might do better for the FI guys since it's geared more towards their needs)
Mobil Delvac 1- 5W-40 (Mobil1 Turbo Diesel Oil is the exact same stuff, 26% Esters!!)
The Shell and the Delvac are both easily found and inexpensive compared to the other guys. The rest might do better, might even blow the "regular" oils away. There's just only one way to know for sure. But, consider that the Delvac and Shell are both API classified as a Heavy Duty Motor Oil (HDMO) and designed for the stress and abuse FI puts on an engine. Also, MIAPLAYA has a great UOA using Turbonetics' oil, which is a re-branded HDMO diesel lube of some kind. Turbonetics won't tell me who supplies them. I think it's Delvac, but I could be wrong. BTW, I'm running that Shell in my car right now to see how well it works in a NA VQ engine.
Will
Great response, thanks for your kind words.
Before I read the list at the end, I was going to offer to try the 300v, which from your writing is the only 100% PAO oil (unless the 300v is listed as one of the 8100 series oil, i thought it was different).
I guess it's either that or the Amsoil TSO, as I can purchase it off-the-shelf at SuperAutbacs.
Thanks for your help, and pelase keep up the great work.
Will
resolute,
I noticed you recommend alot of 40wt oils for boosted applications, with a mix of 30 wts as well. It seems the 40wts offer better protection or similar for high quality 30wts such as your comparision of the tso 0w-30 to m1 0w-40, however, do you take into account the loss in power due to the thicker oil? I'm not saying it is significant, but while the tso 0w-30 performs the same as the m1 0w-40 as far as wear, the 0w-30, being a thinner oil, should put out more power with no other changes, which should pay for itself right there. This is totally thereotical based on fluid properties, but something to think about. I'd love to here what your thoughts on this subject are.
Originally Posted by redlude97
resolute,
Will
This might be a dumb question. I realized that I was adding 5-30 Mobile 1 to 10-30 Mobile 1 which was used for my last oil change. Upon checking my oil level I noticed I was a little low and after i added maybe a quarter quart I noticed it was a different weight. Is this bad?
I would say your biggest problem was wasting your money on Mobil 1 5W-30 and 10W-30, both of which are ok oils, but don't protect any better than the less expensive Castrol GTX.
Will
I usually recommend a 40 wt for the FI guys simply because the HTHS scores are higher, and the film strength greater, with a heavier oil. However, M1 0W-40 is a very thin 40wt vs GC or Amsoil TSO which are very thick 30 wt oils. The 0W-40 had thinned to near the same viscosity as the TSO, so there will be a pretty marginal difference, if any, between the two in terms of power loss to viscous drag. Many tribologists have told me the real difference in viscous drag will not be in any significant hp increase to the wheels, but in overall fuel efficiency when monitered over the course of the OCI. There are companies who like to use dynos to show a power gain, but any gains on a chassis dyno are always questionable, and I would take protection over the minimal hp freed up. This is where an oil like the TSO shines, as it seems to hold up over longer OCI's than the M1, and so the slightly less viscous drag might make a measurable (if small) difference in mpg while still protecting the engine.
Will
Will
