Engine Removal
Old May 17, 2007 | 11:07 AM
SpoolinZ's Avatar
SpoolinZ
Default Engine Removal
I'm ready to take the engine out of my Z but i cant figure where to mount the hooks for the cherry picker. Can anyone help out? Also does anyone know how to disconnect the AC quick disconnect fittings? Thanks a bunch
Old May 17, 2007 | 11:14 AM
1-Slow-Z's Avatar
1-Slow-Z
cut everything you see thats connected to the engine and just yank it out
Old May 17, 2007 | 01:37 PM
Z04's Avatar
Z04
if you are not going to offer good advice, i suggest you stop posting
Old May 17, 2007 | 01:46 PM
DavesZ#3's Avatar
DavesZ#3
Actually, Nissan's official method is to raise the car on a lift then use an engine/trans jack to lower it down. I guess that's why you can't find a place for a lift hook on top.
Old May 17, 2007 | 03:21 PM
rocks's Avatar
rocks
You can buy these plastic things at autozone to dissconnect your ac lines. They are like 3$ for a package of them in diffrent sizes. To lift the engine you lift it by the headers at least that is how i lifed mine when it was out of the car.
Old May 17, 2007 | 07:16 PM
ckiesz's Avatar
ckiesz
Default Engine removal
I just pulled the engine and tranny on my G35. I used one of the top bolts holding the bellhousing to the motor and one of the longish thick bolts on the front of the engine. I had no front end on the car so the engine just came out the front.
You can also disconnect the steering shaft at the rack, unbolt the lower control arms from the crossmember and drop the engine and tranny out the bottom by unbolting the engine crossmember.
Old May 17, 2007 | 07:20 PM
ckiesz's Avatar
ckiesz
Also, you might want to unbolt the AC compressor from the engine and leave it in the engine bay off to the side. That way you don't have to recharge the AC system.
Old May 18, 2007 | 08:15 AM
shushikiary's Avatar
shushikiary
cant you also do the same thing with the power steering pump?
Old May 18, 2007 | 10:09 AM
SpoolinZ's Avatar
SpoolinZ
got the engine out, i just swung the condensor/radiator out of the way, but then it fell and snapped one of the AC lines. Do those plastic autozone things look like little round clips with tabs on them?
Old May 18, 2007 | 02:41 PM
rocks's Avatar
rocks
Yea they are round, you can use the fuel line or ac ones they work the same. The fuel line ones are supposed to be easier to use they are the same sizes. Just ask them for the plastic quick dissconects.
Old May 18, 2007 | 02:49 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
+ 1
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Depravity
Oct 1, 2015 04:49 PM
