Plenum Spacer Issues
Old Mar 17, 2009 | 02:45 PM
SuperMiguel's Avatar
SuperMiguel
Default Plenum Spacer Issues
I just took my car to a shop to install the plenum spacer.. When i was driving back home, when i was neutral position my car rev would go alot less than 1k rev and it almost felt like it was going to shut it self off. Got home and turned the car on and it is kind of shaky and if i leave it normally its revolution will go down and the car will shake more and then they will go to 1k and it will just keep doing this... Any recomendations besides taking it back to the shop tomorrow?? can i drive the car like that??
Old Mar 17, 2009 | 03:05 PM
SuperMiguel
well after doing a bit of looking i found that the guy that installed forgot to isntall the litle pipe that goes behind the plenum (pic)
Old Mar 17, 2009 | 03:08 PM
steven350's Avatar
steven350
(slap on the forehead)
how do you like it so far?
Old Mar 17, 2009 | 03:14 PM
Jeff92se's Avatar
Jeff92se
How do you like your revup airbox mod?
Old Mar 17, 2009 | 03:37 PM
SuperMiguel
well it feels like it lost power... ummm note sure if its because that hose was not in and i drrove for like 20 minutes with out it.. But right now it feels like it lost power could this be posssible?
Old Mar 17, 2009 | 03:44 PM
steven350's Avatar
steven350
Old Mar 17, 2009 | 03:52 PM
freedonutss's Avatar
freedonutss
Make sure the gaskets are aligned properly. If the gasket is no good then your going to feel a power loss.
Old Mar 17, 2009 | 04:12 PM
SuperMiguel
the gasket is this right + http://www.motordyneengineering.com/...amidgasket.jpg
Old Mar 18, 2009 | 09:03 AM
SuperMiguel
ima take it back today to the place where i installed it and have them check the gasket...
Old Mar 18, 2009 | 09:10 AM
Escobar's Avatar
Escobar
make sure everything is sealed properly and re-set the ecu.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
