Clutch Problem
Old 07-11-2009, 10:12 AM
DLH
DLH's Avatar
Default Clutch Problem
Hi Guys
2005 350ZR (Stock)
My clutch pedel started getting softer and softer and gears became more difficult to engage, Now my Peddel is flat on the floor and I cant select gears.
So does my complete clutch need replacing ?
Hydraulic problem ?
Thanks
Old 07-11-2009, 01:59 PM
You need a new clutch. May as well add a flywheel.
Old 07-12-2009, 01:36 AM
DLH
DLH's Avatar
OK, thanks
I just checked and all the fluid is still there, so it must be the clutch.
Old 07-12-2009, 09:28 AM
terrasmak's Avatar
Received 2,296 Likes on 1,653 Posts
Your clutch master or slave is bad. Easy fix , just need to figure out what one failed.
A clutch being out of adjustment makes it hard to select gear, a bad clutch makes it hard to accel cause it will be slipping.
Old 07-12-2009, 10:39 AM
DLH
DLH's Avatar
Makes sense, cause the clutch was not slipping before all this happened.
How do I check which needs to be replaced ??
Where are these 2 located in the engine bay ?
Old 07-12-2009, 11:25 AM
terrasmak's Avatar
slave is on the tranny , the master is on the firewall
Old 07-12-2009, 11:31 AM
DLH
DLH's Avatar
I checked the Master and the Fluid was still perfect and no leaks around the Master,
Could it still be the Slave if the Fluid is still all there in the Master bottle ?
Old 07-18-2009, 11:51 AM
DLH
DLH's Avatar
Update:
So we checked the Master Cylinder and fluid level - all perfect with no leaks
Checked the Slave Cylinder - No leaks - no problems.
We then decieded to take a chance and bleed it - bled it , pumped the clutch pedal - Nothing !!!!! Still pedal down to the floor with no pressure!
That was Thursday afternoon.
Went to the car today (saturday) to try and do some more investigation - To my surprise - Pedal back at the top and working Fine !!!
Drove the car today with no issues. Clutch Pedal feels better that before all of this happened. SO after the car standing more more than a 6 weeks - All Sorted I hope.
Thanks
Old 07-28-2009, 06:54 PM
NissanDrifter06
NissanDrifter06's Avatar
hmm i wonder if my clutch master cylinder is going bad. cuz my clutch pedal likes to suck back down a little bit when i step on the gas hard. or when it rains and i lose traction.
my friends 350z dont have this problem..
Old 07-29-2009, 12:28 AM
DLH
DLH's Avatar
Could be, Im still going to put a better fluid in and change to a braided pipe just to be safe.
Old 07-29-2009, 09:04 AM
terrasmak's Avatar
Just bleed it out for now and see if it happens again, our 05 does the same thing once and a while.
Old 07-29-2009, 10:02 AM
DLH
DLH's Avatar
ok, thanks
Old 12-23-2009, 02:42 AM
DLH
DLH's Avatar
Can you believe it after all this time the Clutch started its messing around yesterday.
Will Bleed it and see what happens!
Old 12-23-2009, 04:43 AM
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
have you flushed the old fluid completely out or just bled and added in what was removed?
Old 12-23-2009, 04:47 AM
DLH
DLH's Avatar
Last time we just Bled a little. This time I think we must flush out and replace all the fluid...
Old 12-23-2009, 04:55 AM
Z1 Performance
Former Sponsor
I would for sure - it's hot and humid where you live and clutch/brake fluid absorbs moisture. As it does, it's boiling temp drops to the floor. To be on the safe side, use a good quality fluid (there are lots out there, no need to go nuts with it for just a stock car) and do it 1 time per year (brakes and clutch)
Uriyo_
09-08-2021 08:46 AM
08-06-2021 06:19 AM
TDPrank
09-28-2015 06:29 AM
Quick Reply: Clutch Problem
