Anyone with a Successful Mishimoto Oil Cooler Install
Old Dec 21, 2009 | 07:48 AM
Zazz93's Avatar
Zazz93
Default Anyone with a Successful Mishimoto Oil Cooler Install
I don't want to turn this into a Mishimoto bash thread, but when searching through the older threads I didn't see a successful install. Everyone has had some type of lasting problem most notiably with noise, yeah noise from an oil cooler. I tried to install the second kit I recieved from the manufacter after having problems with the first (great customer service BTW) but the two kits had the same problem with a whine in the core at anything over 1500 rpm. When I eliminated the core from the system there was no whine. This led me to believe the Z runs a pressure that the kit was not designed for. Also I noticed the AN fittings had a hard time sealing properly. Because these are easy to overtorque I'm not going to blame the kit but the problem is worth noting.
Anyone do this kit on their Z sucessfully? No noises, no leaks.
Old Dec 21, 2009 | 08:26 AM
halfass872's Avatar
halfass872
I'm curious about this as well, since i'll proabbly be installing one this spring. Does this come with a thermostat?
I have their radiator, and it's been a great piece. That's the only thing i have that they make though.
Old Dec 21, 2009 | 08:32 AM
lgear080's Avatar
lgear080
I would go with the stillen/setrab unit. I have it installed and it performs flawlessly
with no install issues...
Old Dec 21, 2009 | 10:11 AM
Zazz93's Avatar
Zazz93
I was going to switch to a Setrab unit and get some custom lines made at a local industrial hose shop. As far as the thermostat i'm still in the air. Here in So Cal it seems temps don't normal stay low enough to be a problem with overcooling. But if they are I'll probably go with the Mocal unit.
Old Dec 21, 2009 | 10:13 AM
Zazz93's Avatar
Zazz93
I also have the radiator and I'm happy with it. But the oil cooler seems to be for cars that don't generate a lot of oil pressure. I'd say stay away until they address the issue.
Old Dec 21, 2009 | 12:20 PM
halfass872's Avatar
halfass872
Good call, will do!
Old Dec 22, 2009 | 11:01 AM
intoZsunset's Avatar
intoZsunset
I had the same issue as you guys do with my set-up, but I thought it only pertained to me. I e-mailed Mishimoto, and actually got a response within the hour. Supposedly, they are releasing a larger capacity oil cooler to solve the issue we are having with it.
Old Dec 31, 2009 | 04:59 PM
P&K350Z's Avatar
P&K350Z
+1. I have the Stillen unit and the highest oil temp I've reached is 93C or about 200F, even while running the supercharger hard. No noise or any issues at all.
Old Dec 31, 2009 | 06:10 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
What size core do they run?
I'm running the HKS oil cooler which comes with a pretty big core, 200 x 200 x 32 (15 row) and i can hear a slight whine when i have the stereo off. I think no matter what, an oil cooler is going to produce a slight amount of "drag" and make some noise.
Old Dec 31, 2009 | 07:11 PM
Zazz93's Avatar
Zazz93
I the core is listed below. It has a similar size to the Stillen and Nismo approved Setrab but my be down on quality.
Rows: 10
Core: 11.81" x 5.31"
Thickness: 1.97"
Braided Hoses: 4ft .75 inch 4ft 9 inch
Braided Hose Fittings: 10AN
Sandwich Plate Screws: -8AN
Old Jan 2, 2010 | 07:21 AM
Zazz93's Avatar
Zazz93
That's odd, when I blew pressurized air through the system, the core was the only thing to pass with little or no noise. Everything else made a noise of some type.
Did you have a problem with the AN fittings? I got two kits from them and one line always had a leak. I though it might be from over torquing the fittings but they don't show signs of over-torquing.
Old Jan 15, 2010 | 01:32 PM
Zazz93's Avatar
Zazz93
Just a heads up, I decided to get some aftermarket lines and fittings from Summit racing and use the Mishimoto core. Also grabed a Mocal Thermostatic adapter and the noise is gone. My guess is the noise were generated in the fittings but I can't say the adapter or lines didn't have an issue.
Old Jan 11, 2011 | 07:27 AM
intoZsunset
Sorry for bringing back such an old thread, but when I went to Formula D this summer. I was admiring Matt Waldin's car, and got to talking to him about everything he uses on it. He mentioned his Mishimoto oil cooler and since I was in the market for one, I asked his personal opinion on the product. He said that the set up was working great, he had no issues, but that he had installed it up front next to his intercooler for better air flow. I found some pics online that you can kind of see it in, but if he uses it, likes it, and has nothing but good things to say about it.. It seems like it's going to be a solid product.
Old Jan 11, 2011 | 07:50 AM
Zazz93's Avatar
Zazz93
A year later and a better understanding, I think they just have a bad adapter design but I can't say the lines were eliminated from the list. The core is working fine for me and I can't really complain considering I still made the kit for less than a Stillen unit (which was my second choice). Does anyone know if they re-spec'd the kit recently?
Old May 31, 2012 | 02:39 PM
ultrabootz's Avatar
ultrabootz
SOrry i know this is an old thread. How is your oil cooler doing? I have a g35 twin turbo and i have no room for a upgraded rad. Oil cooler would probably be best for me. How long of the lines did you end up getting?
Old Jun 13, 2012 | 09:28 AM
Zazz93's Avatar
Zazz93
The kit I bought in '09 had issues, I think the adapter was the culprit, but the core has held up quite well. Ultimately, I replaced everything but the core, so I can't honestly give an opinion on it.
I would however suggest putting a kit together yourself based on the car's needs, boost + VQ = hot oil. Hot oil = average to large cooler.
Old Dec 25, 2012 | 12:16 AM
thekinn's Avatar
thekinn
It looks like Mishimoto is re-introducing this kit. Any thoughts? I had forgotten about this thread when I received an email from Mishimoto recently..
http://www.mishimoto.com/03-09-nissa...ooler-kit.html
Old Dec 25, 2012 | 04:55 AM
taywan's Avatar
taywan
I have the Stillen as well. No issues at all. Easy install.
Old Dec 25, 2012 | 08:23 AM
freddys 350z's Avatar
freddys 350z
i plan on getting the Z1 set up. it used setrab cooler with mocal plate.
Old Mar 1, 2015 | 08:54 PM
Dustman's Avatar
Dustman
And the beat goes on. I just purchased a Mishimoto oilcooler and ran across this thread by accident.I am beginning to wonder if I made a good choice with the buy. I guess I will find out once I get the unit and have it installed in my car. I have a 2006 Z. I got the oilcooler that comes with the thermostatic unit.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
