Transmission help???
Old 10-09-2016, 05:21 PM
the rook
the rook's Avatar
Default Transmission help???
So I was driving to work tonight and the transmission felt like it started slipping. It actually felt very much like when my clutch went out. But unlike when the clutch went out, as I was trying to limp it back home, the service engine light and slip light came on. I turned off the vdc to see if it would help. It didn't but I was unable to turn it back on. Anyone have any ideas???
The slipping got progressively worse as I drove it home.
Old 10-09-2016, 05:52 PM
the rook
the rook's Avatar
I did read that it could be the cam position sensor but the problems I bread weren't exactly the same as mine. I tried pulling off the road. I shut the car off and turned it back on. I had no problems with start up. It turned right over and started. My slipping isn't delayed. It's a repetitive sputtering feeling. The RPM's jump.
Could this still be symptoms of the cam sensor?
Old 10-09-2016, 06:18 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Your Z has a sophisticated diagnostic system. Pull codes first and do some research on what their meaning is.
Old 10-09-2016, 06:23 PM
the rook
the rook's Avatar
Thanks. I'm close to an O'Reilly so I am gonna limp it there in the morning. I was just seeing if anyone might have had the same problem. I'll be at work all night stressing about it. Lol. I just put a clutch in.
Old 10-10-2016, 06:55 AM
the rook
the rook's Avatar
Crankshaft position sensor. Thank goodness!!! Lol. It's actually less expensive than replacing both camshaft sensors too. $42 and a little brisk morning air garage floor labor :-)
Old 10-10-2016, 05:43 PM
the rook
the rook's Avatar
Here you go bro. This is a pic of an automatic apparently for the clutch master cylinder is just above and toward the front of the vehicle on a standard.
absurdparadox
12-12-2017 05:50 PM
Sub zero
Wheels Tires
11-06-2016 05:10 AM
nshelton6506
10-12-2016 04:06 PM
FJJeremy
10-04-2016 09:03 PM
Quick Reply: Transmission help???
