Idler Pulley Removal Mod with Pics
Old Dec 11, 2007 | 11:50 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by QuadCam
It is currently taking up slack. It is not necessary to have it. Keep it if you want to, or remove it if you want to.
so it's just a tensioner? isn't it nice to have a tension adjustment on that side though?
Old Dec 11, 2007 | 11:56 AM
QuadCam's Avatar
QuadCam
no, it is isn't a tensioner. The tensioner is another pulley int he system. This mod doesn't affect the tensioner AT ALL. The pulley really doesn't do anything! I was told by an early G35 owner that Inifiniti used that pulley to drive the radiator fans on the 1st G35s. Infiniti made a mid year change in 2003.5; part of that change included Infiniti switching to electric fans from that point onward.
So, now that pulley just takes up space. With that pulley in place, the belts length is 46.5" Removing the pulley/bracket necessitates the use of a 45.5" belt. Gates part number K060455.
Old Dec 11, 2007 | 11:57 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
no, it is isn't a tensioner. it really doesn't do anything! I was told by an early G35 owner that Inifiniti used that pulley to drive the radiator fans on the 1st G35s. Infiniti made a mid year change in 2003.5; part of that change included Infiniti switching to electric fans from that point onward.
So my guess would be they kept it in so that parts are more interchangeable such as the pulleys and belts, which reduces cost for dealers (less inventory), warehouses, manufacturer, etc
also makes it easier for techs to work on the car so they don't get confused looking at what appears to be 2 different engine configs at first glance...
Old Dec 11, 2007 | 12:03 PM
QuadCam's Avatar
QuadCam
Here's a pic of where the tensioner pulley is:
...and this is how it would look when you are done. as you can see, this doesnt affect the tensioner pulley.
Old Dec 11, 2007 | 12:07 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
wired........leave quadcam alone.....he needs to find the part number for the spacer. Go search the forum or sumthin!! LOL
Quadcam, lmk when you find the part. Ill definitely get in on this! 3lbs off is nice!
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
yeah I have the service manual somewhere on my computer but I was too lazy to find exactly where this info was located in it
carry on :P
Old Dec 11, 2007 | 12:10 PM
QuadCam's Avatar
QuadCam
I'm not sure what models now have the spacer......I was going to use the Infiniti spacer, but I was impatient and went ahead with the project. I was changing my oil on Sunday, and I decided to do this too.
The tech at Infiniti called me today to let me know that he has the spacer for me.
Old Dec 11, 2007 | 12:20 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
let me know how much if you dont want it.
Old Dec 11, 2007 | 12:43 PM
Ztalker's Avatar
Ztalker
nice mod when the time comes for belt replacement. I used to think that idler pulley drives a water pump. Guess i was wrong.
Questions is.......would the same gates belt #K060455 work with UR underdrive crank pulley installed?
Old Dec 11, 2007 | 12:55 PM
QuadCam's Avatar
QuadCam
I don't know. Take a look at the UR underdive belt. The last 3 numbers are usually the length of the belt........e.g. this one says 455...as in 45.5" long.
the stock belt is a 465..............46.5" long.
Old Dec 11, 2007 | 01:19 PM
Ztalker's Avatar
Ztalker
i got underdrive pulley installed already, just wondering if the same size belt would work after the idler pulley is moved.
So, i can order the spacer for the power steering bracket from any infinity dealer.
Old Dec 12, 2007 | 05:46 PM
QuadCam's Avatar
QuadCam
Updated with close up pics of the pulley/bracket and where to cut the bracket. also, added a pic of the part number for the drive belt.
Old Dec 13, 2007 | 07:08 AM
gothchick's Avatar
gothchick
Yeah, i'll be doing this too when it's time to change belts. Thanks for the tip on how to shed 3 more lbs off an already heavy Z! :-)
Old Dec 13, 2007 | 09:05 AM
Escobar's Avatar
Escobar
gets rid of useless crud on the car! Like I said previously, it is a good mod to do when it comes time to change your belts.
Plus, if you have a nice lookign powder coated timing cover waiting to go on your engine, this'll just makes everything look better......
damn, that looks really good.
Old Dec 13, 2007 | 10:39 AM
Quamen's Avatar
Quamen
I'm doing this for my supercharger kit to allow more room for my radiator on my v-mount.
I always thought that the idler was there because if you take it out the belt going from the PS pump to the crank pulley would be very close to the top of the belt on the tensioner pulley when tensioned.
Old Dec 13, 2007 | 11:22 AM
QuadCam's Avatar
QuadCam
no, there is plenty of room between the belt and the tension adjusting pulley. I wouldn't even consider them remotely close to eachother.
Old Dec 14, 2007 | 05:19 PM
Quamen's Avatar
Quamen
I just picked up my belt today. I just have to get some longer bolts for my tensioner bracket since everything on my car is 14mm further out.
Old Dec 16, 2007 | 07:29 PM
  #38
Quamen's Avatar
Quamen
Belt number the belt you specified didn't work for my setup so I am going to pick up something longer this week. However, this could be due to the slight repositioning of my alternator compared to stock which requires slightly longer belt length.
Old Dec 16, 2007 | 09:15 PM
  #39
QuadCam's Avatar
QuadCam
it must be. try the stock belt and see if that works for your custom setup. the stock belt is only 1" longer.
Old Dec 17, 2007 | 05:46 AM
  #40
Quamen's Avatar
Quamen
Lol. I didn't even take the time to try the stock belt before I bought the other. Either way it is a NAPA belt and I can easily return it so no loss to me really.
Thanks
