Turn signals on 08 z
on
Are the turn signal bulbs, the yellow/orange ones on the very top of the headlights, required to be orange? I want pure white ones. Also, are the small leds on the sides of the headlights considered turn signals also? Basically asking general headlight questions and what is or isnt legal.
on
i read somewhere before that the turn signals in the front doesn't have to be amber. it only has to have an amber reflector but the signal itself doesn't have to be. i'm pretty sure it's legal in CA cuz i was looking this up when i was changing the bulbs on the e90 and a lot of th e90 guys are having white/blue front turn signals anyway.
I found chrome covered bulbs on E-Bay. They have a chrome look until turned on, then they go amber. I was looking to get rid of all the amber up front in my 05. Once I swapped out the amber strips inside the housings and added the clear reflectors in the sides of the bumper, they finished things up nicely.
Not sure on the law but I think the color of the light, when signaling, has to be amber.
on
on
Get out your spoon...
http://www.sylvania.com/ConsumerProd...RG-Results.htm
The silverstars will look like this once installed:
And a comparo... from left to right... Stock orange, blue, and silverstar
on
on
Could someone explain something to me:
High & low beam headlamp
HID-D2S
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
3457ALL
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
High mount stop light
LED
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
7440
7440LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
LED
Trunk/Cargo area
158
168
Those are the compatible bulbs for our z's, but I wanted to know why for example, the parking light has 168, then 168all, and then another number 3457 all, and another 3457 ast.
HID-D2S
Parking light
168
3457ALL
Front turn signal
3457ALL
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
LED
License plate
2825
Back up light
7440
Rear sidemarker
LED
Trunk/Cargo area
158
168
on
I went to pep boys, autozone, and some electric company, but they all don't have sylvania silverstars that look white but light up amber. They either have all amber or all white. Does anyone know where else I can look for these? Or do the white ones from sylvania light up amber?
on
bimmian has the bulbs you're looking for. either chrome and blinking white/blue or chrome and blinking amber. you should check the size tho and i had 3 sets of these on my e90. they don't last that long.
http://www.bimmian.com/SOL/90
on
Do the Front turn signals stay amber (whether or not lights are on) and just blinked off when you signal a turn on 08 models? I have a 03 and thinking of converting, Thanks!
It depends on the state you live in, but I'm pretty sure most, if not all, states require amber bulbs, but not white bulbs under amber lenses. Go to your local inspection station and check on it. I'm pretty sure it won't pass inspection if it doesn't have amber bulbs, at least that's how it is in Pennsylvania.
on
1 Post
HID-D2S
Parking light
168
3457ALL
Front turn signal
3457ALL
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
LED
License plate
2825
Back up light
7440
Rear sidemarker
LED
Trunk/Cargo area
158
168
HID-D2S
Parking light
168
3457ALL
Front turn signal
3457ALL
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
LED
License plate
2825
Back up light
7440
Rear sidemarker
LED
Trunk/Cargo area
158
168
on
1 Post
http://edocket.access.gpo.gov/cfr_20...cfr571.108.htm
covers all vehicles but quotes just what covers passenger cars.
Turn signal lamps.................. At or near the front--1 amber on each side of the vertical centerline, at the same height, and as far apart as practicable.
On the rear--1 red or amber on each side of the vertical centerline, at the same height, and as far apart as practicable.
