Sponsored by:
Sponsored by:
How strong is 3M Super Strong Automotive Attachment Tape??
Old 09-01-2012, 11:56 PM
GunslingerG34
GunslingerG34's Avatar
Question How strong is 3M Super Strong Automotive Attachment Tape??
I just got a Shine copy of the C20 spoiler for my ZR, and was told that it is held on with just tape. Is the 3m DS tape really THAT strong??? I hope it is because I really don't care for the idea of drilling in my trunk lid, but I also don't want to lose a spoiler the first time I hit higher speeds! Is the tape strong enough on it's own or should I bite the bullet and put some screws in it too??? Any opinions/advice is greatly appreciated!!!!!
Old 09-02-2012, 12:17 AM
striker27
striker27's Avatar
Yeah I do not think that is going anywhere........
I have had the stock OEM spoiler held on with just 10 pieces of one inch 3m tape at various places to check the fit...
Sadly once I checked the fit I could not get the damn thing off!!
That was in 2005. SO like I said I think you are safe.
Old 09-02-2012, 02:12 AM
KingBaby
Hardest Setting
KingBaby's Avatar
If attached properly, and surface was clean/prepped you should be fine.
Old 09-02-2012, 02:22 AM
JCITY
JCITY's Avatar
If applied correctly,using 3-M tape to attah your spoiler...it ain't going nowhere!
I just removed my OEM spoiler and installed a Blitz.Only used 3-M.
If you bought the spoiler from Shine(and other body parts companies)it did not
come with any tape.You will have to buy some.1/2" tape is the perfect size for mounting your spoiler.You can get 3-M tape from many sources.However,if you want professional results,I'd go to a auto paint/body supply store and get 3-M product geatred for auto use.The 3-M acrylicPLUS attachment tape(PART#06382) is what I use.Also,I recommend getting some adhesive promoter.This productis like a "fresh wipe" that you use prior to attachment.
Just remember,prep of the surface is most important.Clean several times with rubbing alcohol.Since this is summer,the heat of the season is your friend.Its a good idea to get the tape "gummy"before attaching.Peel of the red backing.Let it sit in the sun for a few minutes.In colder weather,its good to warm up the tape with a hair dryer.
As mentioned in another post,this stuff is not movable after you attach!
Do a test fitting.Center the spoiler.Mark the mountimg points om some masking or painters tape on the deck&spoiler.It may be a good idea to have a buddy help
position the spoiler when attaching.Press that sucker down.Give it some pressure for
4-5 min...your done!
That supply shop should also have these.
Old 09-02-2012, 02:28 AM
island03z
island03z's Avatar
The 3m tape is really great stuff. I've had my spoiler attached with only that tape for the last 5 years. Its hung on there even going 130 on the track with no problems so you'll be fine. Just like the other guys said though, make sure you prep it well. I used rubbing alcohol before I put it on.
Old 09-02-2012, 05:18 AM
beezee
beezee's Avatar
Just make sure all surfaces are clean and apply enough pressure as directed
Old 09-02-2012, 06:17 AM
sry110
sry110's Avatar
Beware of the 3m Adhesion Promoter product. It sure makes the tape stick better, but will make your life a living hell if you ever need to remove it.
Old 09-02-2012, 06:31 AM
rpcrowley
rpcrowley's Avatar
I work for 3M in abrasives and know members of 3M's Automotive Aftermarket Division. I'll ask them about the limitations of the tape.
Old 09-02-2012, 10:13 AM
terrasmak's Avatar
Received 2,296 Likes on 1,653 Posts
It will hold all the way to the point it falls off.
Either way your paint is getting messed up, just drill some holes.
Old 09-02-2012, 05:11 PM
NePa350z
NePa350z's Avatar
It will not mess up your paint, just make sure to prep the trunk before applying, I work in a body shop and constantly use 3m tape, I can't stress enough to make sure the area is cleaned well.
Old 09-02-2012, 05:25 PM
ALO8
ALO8's Avatar
clean with dawn? rubbing alcohol?
Old 09-02-2012, 05:27 PM
ALO8
ALO8's Avatar
without the Adhesion Promoter, i dont the tape will hold
Old 09-02-2012, 05:46 PM
big_dish
big_dish's Avatar
Its Super Strong.
Old 09-02-2012, 06:22 PM
EddyHruby
EddyHruby's Avatar
Old 09-02-2012, 09:55 PM
GunslingerG34
Well, it sounds like the tape WILL work. Thanks for the replies guys!!!! Now I've just got to get it painted....................
Old 09-03-2012, 06:03 PM
sry110
sry110's Avatar
It definitely holds without the adhesion promoter, at least enough to keep something like an OEM or Blitz spoiler in place.
Old 06-11-2013, 12:24 PM
shystieone
shystieone's Avatar
i apologize for reviving an old topic, but I've had the EVO-R blitz replica spoiler on for about 4.5 yrs using the 3m tape that was attached to the spoiler. Held on fine, but now I want to take off the spoiler and go for an OEM look, while also making the hatch struts usable again (trunk bopped my head a few times). Will I rip off my paint/clear coat if I try to remove the spoiler, or is it safe enough to do so? If it helps, I washed the surface with CAR SOAP, not dishwashing liquid/alcohol/etc before I installed the spoiler in case I ever want to remove the spoiler. Thanks
Old 06-11-2013, 12:56 PM
Chebosto
Chebosto's Avatar
you should be able to remove fine, you can help the removal process by heating up the edges of the spoiler with a heat gun (dont get that close that you damage the blitz spoiler) and lift up. the hatch paint, if its OEM should be ok.
you can also use some floss doubled up and get underneath the edge and 'saw' the tape along with the heat gun and gentle prying up...
Old 06-11-2013, 04:30 PM
shystieone
shystieone's Avatar
thanks, I'll try to tackle this during the weekend.. might take a while
10-04-2015 07:55 PM
Extreme Dimensions
Southern California
09-24-2015 03:35 PM
Quick Reply: How strong is 3M Super Strong Automotive Attachment Tape??
