Yaw sensor please help
So I've been researching about how to mount a switch to fully disable the vdc.
I cut the power wire on the yaw sensor connected it to the switch to test it and it didn't function at all. So i back tracked, took the switch out of situation and hooked the power wire for the yaw sensor back together and nothing.
If anyone can chime in it'd be great.
03 350z touring
i am very electrically inclined and thats why im confused.
03 350z touring
03 350z touring
03 350z touring
Master
how about you just stick to one thread and not make multiple on the same thing
https://my350z.com/forum/engine-and-...ease-help.html
The switch is good, i reconnected the power wire and took out the switch and still the vdc and slip lights are still on like the wires aren't connected together.
https://my350z.com/forum/engine-driv...ed-button.html Works great, and it also links to a prior thread about doing this
I don't understand why the power wire (orange) is acting as if it isn't getting any power. I've reset the ecu already and no change. Connect the power wire together with no switch with ecu reset, no change.
I've read both of those already, and just reread them to make sure i didn't miss anything.
im having this same issue, did you ever get it resolved?
z33_Lemans (03-26-2023)
ThomBoh
Southern California
06-01-2016 03:23 AM
