APS TT and Oil Pressure
on
Hi Guys,
Can you perhaps tell me what the oil pressure reading should be on APS TT install with rev up oil pump installed when :
- Cold
- Hot
- WOT
Thanks
- Cold
- Hot
- WOT
Thanks
on
I have this setup but with the Nismo oil Pump (I believe) and a GTM external oil cooler. Cold pegs the gauge at 120 psi 1100 rpm, Hot 60 psi at 2700 rpm 40 psi at idle and at WOT 4000 rpms 75psi. This is what I am seeing on the factory oil pressure gauge.
Turbo Whore
on
1 Post
I have a rev-up oil pump and my oil pressure numbers are identical to when the car was stock.
on
Those all seem really high...I don't recall exactly what mine reads in those various situations, but I definitely don't peg the gauge when cold and idle is more like 18-20psi when it's fully warmed up. Cold start is somewhere between 60-80psi
Same exact readings
on
Yes, I only fill to the low mark, I have a built-sleeved motor, with camfered oil passages. That shouldn't raise the pump pressure only lower it maybe.
on
on
Yeah, it sure has been. Are you going to this upcoming spring meet?...
http://www.chicagoz.com/forums/showt...377#post283377
I'm thinking about coming out to have GRD do some work and then heading to this meet. Maybe I'll see you there.
Turbo Whore
on
1 Post
on
Turbo Whore
on
1 Post
You have the EVO TT and think it sounds like a 4 banger?? I don't know what EVO TT I got, but mine definitely doesn't sound like that. It's awesome, no rasp, deep and rumbly at low RPMs and very strong at partial throttle and I can barely hear it at WOT.
Originally Posted by noer View Post
Yes.. X-pipe rocks.. I hated the sound b4 and now it sounds like a V6 and not a 4 cylinder.. no rasp.. and performance still good
I was actually thinking about doing this for the AAM dual 3"..... b/c i'm NA for now but am going TT later.... Will that help at all since i'm still NA????
Edit to my previous post.
After driving the car for a day or so I now see that my pressure at idle sits much lower than stock, but raises immediately when I press the gas, my builder says this is normal at my lowered compression. However, I am running a super thin 5w-30 right now during break-in and may get slightly higher pressure when boosing and running 15w-50.
