Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
Old 04-26-2012, 07:25 PM
  #181
SurraTT
SurraTT's Avatar
Originally Posted by rcdash
Yeah, I'd just be keeping the stock ECU around to sit on the CAN port, but it'd need to see the MAF, crank, cam, and a few other sensors. The problem is that if the stock ECU is on the CAN port, then the Haltech can't be (as it's not designed to be so there'd be collisions reading/responding to OBD for example), so it wouldn't be able to read the various CAN parameters, which would really limit its usefulness. Definitely needs to be thought through...
This new ECU is definitely worth it though, for the flex fuel support, more maps, more sensors, failsafes, etc.
Thast a good idea, I can see this working.
Use the haltech to run the motor, DBW, cruise, all that stuff.
the stock ecu will have to be happy enough to pass obd2 and control AT.
Why cant the haltech and ecu be on the CAN lines at same time? The current Haltech does this i think..
I can most likely make this work. I have all the connectors and stuff. Ive messed with the Z ecu swap a lot.
Old 04-27-2012, 08:15 AM
  #182
rcdash
rcdash's Avatar
It would likely require a feature to disable CAN broadcasting by the Haltech to prevent packet collisions on the bus. Consider what would happen when a scanner tries to read the OBD port? Both ECUs would respond with data.
Old 04-27-2012, 09:12 AM
  #183
binder
binder's Avatar
Originally Posted by MI 35th
Feedback: 2 days ago I brought the Z back to Cincy from Louisville, drove in the rain back home. Managed 26 mpg a 75 mph. This was on E85 on a built motor BP ST setup.
The car runs extremely smooth, even better than the Haltech Red-Box, I love the traction control functionality and Boost By Gear setup. Amazing, that the car just becomes more controllable.
Onto the E85 managed to find fast for 3.20 a gallon plus $1.00 off from my Kroger Plus card, Filled my tank for $2.20 a gallon on E85. The car runs and starts perfect.
Hal has set a soft rev-limit to 5K and 0psi boost cut until the car reaches a temp of 100 degrees.
Brake boosting is absolutely one of my favorite features.
The car idles much smoother, no more up and down from it transitioning to and from the ECU.
Im sure it does a lot more, but for me this is enough. I was happy I upgraded.
Cruise Control is a little different than OEM, but it works using factory buttons and works well.
Don, what sensor did you have to use to get the flex fuel support and how much did it cost? I'm tired of being nervous about running out of e85 on my long trips.
also, for some weird reason I lost cruise control. When i try to set it, it just blinks rapidly.
How did you get boost by gear? what year is your car? i didn't think the earlier versions (mine is an 03) had a sensor to pick up gears. I was boost by speed but since 1.10 came out i lost my wheel sensors so no more of that for me.
Old 04-27-2012, 09:56 AM
  #184
str8dum1
str8dum1's Avatar
by gear he means by speed (unless like you suggest dynosty added a gear sensor). since you can only go so fast in each gear, thats why its normally referenced like that.
Old 04-27-2012, 09:57 AM
  #185
binder
binder's Avatar
oic, well i lost speed sensors in 1.10 so i can no longer do that
Old 04-27-2012, 10:42 AM
  #186
rcdash
rcdash's Avatar
The Haltech sensor for flex fuel works directly with the new unit. I don't think there's a way to get it to work with the old Haltech PNP Harness units... (You have the original Haltech unit, right Jeff?)
Old 04-27-2012, 11:23 AM
  #187
binder
binder's Avatar
ya, i'm toying with the idea of switching BUT if i have to pay for a 500$ sensor on top of a new unit it's out of my pricerange for what i need. If it was just the price for a new unit i could probably justify that but not 3 grand just for flex fuel.
Old 04-27-2012, 02:54 PM
  #188
MI 35th
OGPremierMafia
MI 35th's Avatar
Jeff,
I have an 05 Rev-Up
My Cruise was relocated to my center console from my wheel because of the aftermarket wheel, it works just like stock otherwise for me. No idea how it should be any different.
The unit has a can bus for additional sensors so wheels speed or gear position shouldn't be hard to add. I believe mine had it stock.
As for the E85 flex fuel sensor it is a god send. I was out on the other side of town and couldn't find E85 so I just filled up with 93 and kept on chugging, it drives the same just a little slower and to me it doesn't change the power enough because Im choked out with a little hot side anyway.
I believe the sensor was 500 but not sure.
Call and talk to Dustin @ Dynosty on Mon he has all of those answers and they know engine and ecu better than I do, Im learning as I go here.
Old 04-27-2012, 03:13 PM
  #189
str8dum1
str8dum1's Avatar
can someone post a link to the ECU manager 11.0?
Old 04-27-2012, 05:22 PM
  #190
rcdash
rcdash's Avatar
I don't think the final version has been released quite yet...
Old 05-01-2012, 10:13 AM
  #191
CrazyVQ35tt
CrazyVQ35tt's Avatar
With this ECU is it possible to remove the factory narrowband o2 and just use the wideband o2 sensors without throwing a engine code?
Old 05-01-2012, 10:35 AM
  #192
str8dum1
str8dum1's Avatar
I dont see why it needs any factory components except for the haltech widebands.
Old 05-01-2012, 10:42 AM
  #193
Dynosty
Vendor - Former Vendor
Dynosty's Avatar
Yes, you can unselect the narrowbands in the setup page and then it will not throw a code for them. Also you can repurpose the CEL into a shift light, knock light, or just set it to off if you desire.
Old 05-01-2012, 03:06 PM
  #194
Kwame
Kwame's Avatar
I need to place my order for one of these ASAP!
Old 05-11-2012, 05:44 AM
  #195
MR RIZK
MR RIZK's Avatar
HAL can you confirm that the supplied base map in the software is configured with the correct settings to suit the VQ35. For example hard to know values like cam solenoid frequency and related attributes or evap settings etc
If the map is pre-configured with the "hard to know" values it would be awesome.
FYI: Software is now available via the update feature in the manager.
Old 05-11-2012, 06:53 AM
  #196
str8dum1
str8dum1's Avatar
edit: hmm my proefi has the cams at 250hz while the haltech has them at 300hz
have to get the software to check out the base maps
Old 05-11-2012, 07:22 AM
  #197
athenG
athenG's Avatar
+1 ..
Old 05-11-2012, 07:38 AM
  #198
Glex25
Glex25's Avatar
Any new in the ECU manager compared to the one that was given to us previously?
Old 05-11-2012, 09:44 AM
  #199
str8dum1
str8dum1's Avatar
so you can control the O2 heaters and Evap system.
Is that stuff open access in Uprev yet?
damn that 11.1 looks awesome. so simply laid out compared to my system.
Very nice!
Old 05-11-2012, 12:38 PM
  #200
binder
binder's Avatar
so i can use the new one with my 1.10 firmware and the old unit?
Maybe i'll get wheel sensors back!
Quick Reply: Dynosty: Haltech 350Z Pro Plug-In - OEM ECU Replacement
