Ultimate Guide to storing your Z/G for the winter
#61
on
My car has done a lot of hibernation over the past few years, sat once for a little over two and a half years.
Besides doing the basic stuff like a complete inspection of all the fluids and components, replacing the battery, changing the oil and adding fresh fuel; the only major thing I really did was remove all the spark plugs, add a few drops of oil to each cylinder, turn the car over a few times using just the starter to get everything circulating, that's it! Started up on the first try like it always has.
Once you get it out of your garage I recommend going to an open area to test everything out, I found that my brakes needed to be broken in a bit before they were operating normally. Another tip is prior to storing leave the car in gear with the parking brake disengaged. Learned that the hard way.
I moved to Germany last year and had the Z shipped here as well, long story short it sat in my father in laws garage until a few weeks ago, I accidentally left the parking brake on and now it does not engage properly, there is way to much play in it. On the to do list along with some other projects while it sits this winter.
#62
on
This is a great thread! Im not seeing much on here in regards to car covers and critters. I am in Cleveland, Ohio so its gonna be nasty in the winter. I will keeping my Z a detached garage that is kind of set back in some trees. How do you guys keep critters and terrorist varmints from getting up into the wiring? I was told moth ***** and rat traps are a good idea. Also, I'm looking at car covers that range anywhere from $25 to $160. I know you get what you pay for, but considering its going to be in the garage, is it really necessary to splurge on a car cover or will a $40 one do just fine? For what its worth, this is my first year storing a car!
Thanks in advance!
Thanks in advance!
#63
on
Thanks in advance!
Thanks in advance!
#64
Senior Super Moderator
Agreed that the car has to be superclean before putting on the cover. I normally don't have problems with critters during storage, but I recently started using dryer sheets inside the car and engine compartment (near the battery) to deter the mice.
I used to use hedge *****, if you can find them. Those go in the corners of the garage.
#66
Also, you won't have problems if the car is stored for just a few months.
#67
Depends but you can put your car up on jack stands and take the wheels/tires off to store inside your house. Or you could get wheel dollies and leave your wheels/tires on the car but store the whole car on those dollies.
#68
I've done it both ways. Never had problems either way.
#69
Prepping for Winter?
I'm about to head back to school in Indiana(-5F the other day) for the winter, and for the first time I'm going to be taking my Z with me.
I've been doing some research on here and I plan on checking all my fluids, and maybe putting fuel stabilizer in the gas? I also have a pretty new set of tires and a car cover.
Unfortunately, the car will have to spend it's time in an open garage the whole time.
What can I do to take car of my Z while I'm there?
#70
General & DIY Moderator
Has the Z been recently washed, clayed and waxed? Are the "pretty new set of tires" actual snow tires? Is the car cover the all-season type?
No need for fuel stabilizer if you're driving the car at least once a week. If you're not driving it, why are you taking it?
#71
Check your coolant! Too much water, and you could have an expensive mess on your hands.
#72
They are not snow tires. I'm prepared to slow down and take my time if the roads get bad.
The cover is all-weather.
If needed, I'd probably enjoy taking the car out every week. But for the most part, it will just be sitting there. I'm taking it because it will allow me to go back and forth between home without finding rides or having someone pick me up. The RWD is not a good choice for this, but that's how it ended up.
#73
I'm hoping to get a wash and wax in before I leave. It's just about the warmest it's going to get right now, so maybe I'll do it now
#74
As dkmura states, you need snow tires when driving in snow or on ice (i.e., frozen ground).
I’ve test driven all-season tires during the winter, and they are not adequate on a 350z. Performance tires are useless in the winter.
You don’t need a “fuel stabilizer.” Ethanol is probably added to gasoline sold in Indiana.
#75
I have Yokohama envigor on the front and Yokohama sport in the back.
I'll start looking into winter tires. I'm trying to buy a set of wheels right now, I could probably swing a set of winter tires on them instead of swapping my current tires.
Would I be ok just buying rear winter tires?
#76
on
If snow is likely to happen AND you must be able to move the car, get snow tires. If you can afford to just leave it in the garage on snow days, I wouldn't spend the money.
#77
Oh, look fridge gnome! A full thread about winterizing the Z car! Who would have thought?
*threadsmerged*
*threadsmerged*
#78
on
I know this is old thread but thanks for the guide and i have one question: I am storing my z outside, should i start it or not? I know people here say dont but everyone i know is telling i need to start a car. I have been storing my z since november and so far i have started it 2 times. it will be stored till march. Do i keep starting it once a month(since i already did 2 times) or just leave it till March?
#79
Leave it alone. Put some Seafoam or Stabl fuel additive in the tank with a full tank of gas, if you haven't already. Otherwise, just let it sit. I've heard that everytime you start the car, you create condensation in the lines which doesn't get burned off if you let the car idle.
Just a thought.
Just a thought.
#80
Just a thought.
Just a thought.
