puddle on passenger side floor
Old 07-12-2009, 07:20 PM
joeyz12
joeyz12's Avatar
Default puddle on passenger side floor
ok so last night there was a huge thunderstorm and it was raining for about an hour like cats and dogs. it was pouring!! I happened to be driving on the highway at this time going to a friends house. i came into the car this morning and smelt a weird kind of mildew smell. at first i thought maybe it was the water from me and my girlfriends shoes but when i lifted the passenger side mat the floor was soaking. anyone else have this issue? the driver side is completely dry
Old 07-12-2009, 07:23 PM
03aeroZ
03aeroZ's Avatar
......did she have an accident and not tell you???? j/k
No idea. Any water spots that would make you believe you had a leak? Window motor going out? Mine needs to be rolled back up about every other time someone gets in the passenger side.
Old 07-12-2009, 07:27 PM
joeyz12
joeyz12's Avatar
the funny thing is nothing else is wet other than the little square area under the mat. not even the sides or by the seat just where you put your feet
Old 07-12-2009, 07:30 PM
03aeroZ
03aeroZ's Avatar
Old 07-12-2009, 08:20 PM
Gibbs
Know it all
Gibbs's Avatar
Mabey a ruber plug under under that side of the car fell off.
Old 07-12-2009, 08:35 PM
Swimminggerman
Swimminggerman's Avatar
I once was in a good rainstorm or two and had water come in around the firewall area. It rains here a whole lot more than anywhere else in US. its the wet side of the big island Hawaii. anyways, water came in and I thought WTF, this car is new. Only happened about 2-3 times and never again since. not sure what was going on. Dont think i had the ac on either so?????? came in driver side. few good size drops 1/4 cup worth
Old 07-12-2009, 09:32 PM
zenki_z33
zenki_z33's Avatar
Check your grommet on the firewall(the one that the engine harness runs through) it could be loose. Good luck
Old 07-13-2009, 05:42 AM
joeyz12
joeyz12's Avatar
thanks but im a newbie where is the firewall?
Old 07-13-2009, 08:59 AM
PerfZ
PerfZ's Avatar
The wall that separates the engine compartment from the cabin.
Old 07-13-2009, 05:50 PM
kevincat
kevincat's Avatar
was your ac on? if so it might be your ac clogging up and dumping the water onto your pass. side
Old 07-13-2009, 11:47 PM
350ZTheStandard
350ZTheStandard's Avatar
The AC drain hose to the outside (for condensation) is on the passengers side, GF's big feet may have knocked it loose. Dry the water & floor mat and let it air out before putting it all back together. Good luck
Old 07-14-2009, 11:53 AM
joeyz12
joeyz12's Avatar
how do i get to the hose?
Old 07-14-2009, 03:42 PM
kevincat
kevincat's Avatar
remove the carpet. and then remove the the floor carpet and it should be right there, underneath all the foam mats and what not. quite simple. i doubt your gf kicked it loose. unless she is 7 foot tall and sit with her feet digging up the carpet. since is is nicely tucked closed to the console and firewall. it is prob clogged. just yank the hose out and blow some air in it and youre good to go.
Old 07-14-2009, 05:54 PM
bleufiend
bleufiend's Avatar
Itd have to either be a door seal leaking (not likely though) or like the other peeps have posted, your a/c drain hose is leaking or the problem I had which someone mentioned earlier and thats the firewall grommet for the harness. Nissan the genius's that they are decided to run the grommet parrel rather then vertical and the grommet sits underneath the fusebox/battery. Its been so long that I fixed mine I cant remem how exactly to get to it. I if you take out the covers over the battery on that side you might be able to get to it. If not then its under the battery. But thats where my leak was coming from and when it rains water just puddles up underneath there.
Old 07-17-2009, 05:46 AM
oozero
oozero's Avatar
yea i have the same problem right now also.. when it rains i have a freaking pond built up on the passenger side of my car.. when i feel on the passenger side up under the dash where all the cables are it is soaking wet... im prolly just going to go get some sealent or something IDK but hopefully it works.. my car is starting to stink!
Old 07-17-2009, 10:01 AM
Boogshag
Boogshag's Avatar
I havent even gotten to drive my Z yet cause I bought it wrecked and am repairing it, but i had to completely strip it down, and there is a rear windshield washer line (hose) that is strung from the front of the car to the rear along the pass. side of the car only. Was it water for sure, or could it have been light blue windshield washer fluid?
Old 07-17-2009, 10:03 AM
Boogshag
Boogshag's Avatar
But, since you mention it rained really hard the night before, I bet that its neither the A/C or the washer fluid. its gotta be a window or door seal problem.
Old 07-17-2009, 10:30 AM
y0shi
y0shi's Avatar
Did you ever change your hatch struts?? Make sure the bolts are tightened.
Old 07-22-2009, 12:19 AM
350ZTheStandard
OP, so what was the problem???
Old 07-22-2009, 01:45 AM
tj2009
tj2009's Avatar
i had this problem before and i fix it the firewall was loose in my car so check the firewall
Quick Reply: puddle on passenger side floor
