I turn off the car and my windows roll down...wtf?
on
Ya, so I can't take my car anywhere if I expect to park it anywhere. As soon as I turn off my car, my windows rolls down at the same time and I can't roll them up using the key in the door or from the inside. Now, if I turn off the car, watch the windows roll down, then turn the key clockwise again, the windows will stop rolling down, turn the key counter clockwise again and they continue down. Now, I have disconnected my battery to try to reset a CEL code from a stupid sticking T-Stat which I'm going to replace with a NISMO version. Now, my windows have learned to go up and down at the top and bottom of each switch. If fact, they never forgot.
Could my regulator motors be going out at the same time? Just seems way to weird to go out at the same time.
I've read that you could take off the panels to push a button on the motors to reset them, but that's gonna blow, I have a warranty, I need to use it. Plus, I want them to make sure that this T-Stat didn't cause any other issues.
Here's what happens:
- In the car, car is running, windows are up
- Turn the car off, open the door, windows roll down
- Can not control the window as all
- Can only stop the window from rolling down by reinserting the key into the ignition again, but once pulled it rolls all the way down into the door
on
I do believe that is a feature, not an issue. Once you open the driver door, or after a defined period of time, the windows will no longer operate with the ignition off.
From the tech manual:
RETAINED POWER OPERATION
When the ignition switch is turned to the OFF position from ON or START position.
Power is supplied for 45 seconds
to power window main switch terminal 10
from BCM terminal 53.
When power and ground are supplied, the BCM continues to be energized, and the power window can be operated.
The retained power operation is canceled when the driver side door is opened.
on
Oh and one more thing, using the key in the door handle to role up the windows don't work either.
on
Aha, but concentrate on the positive: Our 3.5 engine has been awarded the "Best Motor of the Automotive Industry" 14 years running by J. D. Power Index. Great cooling system. FLAWLESS AT (not so the MT, though). Overall "Much Better Than Average" reliability, according to CR Magazine...All in all, I truly believe we have a g-r-e-a-t Sports car in our driveway, dude! BTW, where's McKinney in TX? My son's stationed at the South Laredo Sector with the B.P., and just loves it there---'xept for the scorching temperatures, of course! I'm a CBP Officer down here at Puerto Rico, and your new friend!
on
SO true, Filthy (I feel bad calling you like that!) I got one of 'em motors at AutoZone fer $160.00, plus labor (under $200.00). Lifetime guarantee. Peace of mind has no price, dude!
did you figure out what the problem was with this? it is happening to me right now and I cant go anywhere because of the fact that my windows go down right when I take my keys out and open the door.. if anyone knows a way to fix this, your help would be appreciated.
on
Guess it's a secret... Maybe he fixed it and sold the car...lol. But you would think he would have revisited this thread on it's third anniversary of figuring it out..
on
must be a secret cause im having the same problem and only started happening after i got my battery changed and my whole alarm system was messed up too. would go off when the car was unlocked... computer maybe?? anyone have any ideas?
