Window Motor
on
Window Motor
The passanger window will not go up or down. The switch makes clicking noises when I switch the switch to make it go down.... Would you guys know what the problem is? Is it the motor or something with the switch? Or something more in depth.
Thanks
03 350 touring
Thanks
03 350 touring
I was being an ******* to one chick I was with and was playing freeze out. When I finally decided to roll the windows up I started to freak out in my head (had to try to look cool) thinking my window motor went out with the window down and I was phucked.
Then turned off the window lock and it went up and was very relieved.
on
Yeah the lock is off. And sometimes the auto index works, but only sometimes.
General & DIY Moderator
Your window motor is going out. You'll need to replace it, so do a search on the DIY section (search) or take it to a qualified tech for repair. There's a TON of threads on this topic...
11-09-2020 10:27 AM
04-04-2016 07:52 AM
