noob question about torque wrench
ok so i understand how to use one and all. my question is, my wrench only clicks when a bolt is in a position such as the lug nuts. but if a bolt is at an angle like spark plugs or if the bolt is straight up or straight down, it doesnt click. is this how torque wrenches are suppose to me? does it only click in certain position?
General & DIY Moderator
As dcains says, your torque wrench should click even if it's tilted (or upside down for that matter). Of course, you'll want to make sure the fastener is not cross-threaded and has a full grip on the bolt or nut you're attempting to torque.
A friendly word of advice: If you don't know how to use a torque wrench, don't go playing around with your spark plugs. It's a pain to re-thread a stripped plug hole.
found the problem. the spring and ball thing inside the wrench was defective/busted, when and got a new one and work just fine. thanks for the help fellas
