2004 Nissan 350Z gauges stop working
on
The ABS and Brake lights lite up ( SLIP also ) . The A/C also stopped working. I brought it to my local mechcanic and he thought it was blew a fuse and it was not. Now, the Speedometer also stopped working. Any idea whats wrong?
ECU failure would kill the motor, BCM and I believe another computer may do this
It's the Unified A/C & Meter Amp. Should be a white box located under the stereo with a ribbon cable going to it.
As I stated earlier, it’s likely a problem with your ECU.
Nissan has a service bulletin describing this issue (code U1001). Its cause could be a poor ground connection in the harness (at the engine and/or the dash). Nissan recommends unplugging the harness, cleaning the connection, and reconnecting the harness.
I think you need to reset the engine light after doing this.
_____________________________
EDIT: I should have stated that ECU is a generic term that includes multiple electronic control devices (up to 80 now in modern cars).
Thoha Hassan’s problem (code U1001) is a ECU failure specific to the ECM, which is an individual Nissan ECU component.
EnjukuRacing
09-11-2015 08:30 AM
VQA33
Wheels Tires
09-08-2015 08:30 PM
