350z overheating
Old 06-08-2015, 01:38 PM
gearhead350
gearhead350's Avatar
Default 350z overheating
My 2003 base 350z is overheating, I replaced the thermostat, raditor cap, had the radiator pressure tested (it's fine), water pump is fine apparently, and no leaks...any advice? Please help
tatman7 (07-18-2015)
Old 06-08-2015, 01:44 PM
PerfZ
PerfZ's Avatar
Bleed, and bleed again. Repeat as needed......
Old 06-08-2015, 03:46 PM
gearhead350
Bled the system, still overheating
Old 06-08-2015, 03:47 PM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
are the fans kicking on?
Old 06-08-2015, 03:48 PM
gearhead350
Yes fans turn on
Old 06-08-2015, 07:10 PM
Jimmytherustler
Jimmytherustler's Avatar
Pressure test, leave system pressure for a little while and pull your plugs. Look inside your cylinders, you may have leaking head gaskets.
Old 06-08-2015, 07:17 PM
gearhead350
I'm getting it inspected tomorrow morning
Old 06-08-2015, 07:49 PM
JoseValencia27
JoseValencia27's Avatar
Could be your running too lean on fuel?
Old 06-08-2015, 07:50 PM
Jimmytherustler
Sweet! Let us know what they find. As a side note, although your fans may be coming on, there is a self test using Consult which requests the fans to come on, and you can control a high/medium/low load and depending on your fans' reaction, the motors may be weak. So, you COULD have weak fans. For your wallet's sake I hope it's something as simple as that.
Old 06-08-2015, 08:04 PM
gearhead350
Yeah me too, I need a new rack and pinion rack too
Old 06-08-2015, 08:14 PM
Jimmytherustler
Power steering is overrated
Old 06-08-2015, 08:29 PM
Syner
Syner's Avatar
How many times did you try bleeding? These cars are notorious for holding bubbles.
Old 06-08-2015, 08:45 PM
gearhead350
I bled it 3 times, it started overheating the second I tried it with the air conditioning, but then it overheated again even without the air conditioning and the heater on
Old 06-09-2015, 02:27 AM
kham25
kham25's Avatar
I changed the coolant tried 3x bleeding. Funnel, bleeder screw, squeezing radiator hoses every damn thing. Fed up took it to dealer no more overheating or issues. Pay and get it done.This car truly is a ***** to bleed correctly..
Old 06-09-2015, 04:05 AM
gearhead350
Yup I can tell, I'm getting ready to take her in
Old 06-09-2015, 08:43 AM
lolsupfoo
lolsupfoo's Avatar
sounds like air bubbles to me, been there done that these cars are known for this.
Old 06-09-2015, 09:04 AM
Frank_White
Frank_White's Avatar
try bleeding it again, if that doesn't work take it in get it checked out
Old 06-09-2015, 11:10 AM
Sleepiedaze
Sleepiedaze's Avatar
best way I dealt with air bubbles.
jacked the front of the car up turn car on with radiator cap off for a few watch air bubbles come up. put cap on let it do its thing and take it off again with the engine still running. gets air bubbles out and fill radiator back up. but then again your taking it to a shop to get it inspected so not to sure why your asking for help.
Old 06-09-2015, 01:51 PM
gearhead350
I asked for help cuz I was gonna try to do it myself, I bled it over and over again but nothing, turns out my radiator is clogged it's getting a high pressure flush right now
Old 06-10-2015, 12:55 AM
Underscore_Hero
Underscore_Hero's Avatar
Forsberg makes it sound so easy....
Quick Reply: 350z overheating
