Shop Builds Temp moving posts for some clean up of this section.
IPS Project G35 Sedan.... MONSTER! ver 2
Old 04-30-2012, 06:15 PM
3kgtSL91
3kgtSL91's Avatar
Originally Posted by rcdash
Everyone loses in this type of scenario but based on what I've heard of SP, I'm sure they will come through for their customer!
honestly, not sure about that... they had my car since 08 (before i had my own shop) and it is still not done, though i prepaid for everything
Old 04-30-2012, 06:23 PM
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
Yeah, I told Larry that the Chris@SP account still appears to be active. Agreed that everyone loses in this situation. I unfortunately know this first hand due to being ripped off on an auto trans build a couple years ago. I never recouped the losses from that.
Old 05-01-2012, 03:54 AM
Quamen
Quamen's Avatar
Originally Posted by 3kgtSL91
torque converter is back.. and as we found out, there was nothing special done to it... now, on the other hand, it's all good
I'm interested to know how that torque converter got built? Typically that style of converter isn't good for power. I went with a Circle D billet in my TH400.
Old 05-01-2012, 04:01 AM
3kgtSL91
3kgtSL91's Avatar
we use coan in a our race car (runs 7s in a 1/4 mile), but since was not a coan converter from the beginning they weren't sure if they can make it work or not, but they were able to... but i am not exactly sure what exactly they did to it... but we'll see once it's up and running.
Old 05-01-2012, 04:04 AM
Quamen
Quamen's Avatar
I'm sure they had to do quite a bit. I had a similar converter from TCI and the trans shop I know that also does 7s cars said it wouldn't even be worth it. Looking forward to results! It has been a long time coming for Vlad since I last saw his car at SP like three years ago.
Old 05-01-2012, 06:29 AM
rcdash
rcdash's Avatar
Quamen, can you explain what the mechanical differences are that preclude the necessary modifications across different models? My understanding was that all TCs are fundamentally similar.
Old 05-01-2012, 07:27 AM
Quamen
Quamen's Avatar
The functionality of a TH350/400 converter is essentially the same across the board. However there are some different dimensions and material specifications between converters to accommodate for their application. Some do not have very strong casings because they are not designed for high rpm's or pressures while others will have beefy cases.
My particular converter has an entire billet backplate to prevent it from ballooning during high pressure situations.
Old 05-01-2012, 08:45 AM
rcdash
rcdash's Avatar
That makes sense - thank you.
Old 05-01-2012, 12:19 PM
3kgtSL91
3kgtSL91's Avatar
it is a custom specd 9 inch coan convertor with a billet cnc aluminum stator
Old 05-01-2012, 02:38 PM
Quamen
Quamen's Avatar
What stall speed?
Old 05-02-2012, 03:47 AM
3kgtSL91
3kgtSL91's Avatar
we won't know until we test it at the track
Old 05-02-2012, 06:19 AM
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
That's a given. But what stall speed did you order? What stall speed are you aiming/hoping for?
Old 05-08-2012, 10:26 AM
3kgtSL91
3kgtSL91's Avatar
idk, 1500-2000
Old 05-08-2012, 10:27 AM
3kgtSL91
3kgtSL91's Avatar
trans is back from RPM:
Old 05-08-2012, 11:55 AM
str8dum1
str8dum1's Avatar
stall wouldnt be that low.... at least hope not..
Old 05-08-2012, 12:16 PM
rcdash
rcdash's Avatar
You will be able to tell quickly on the street - bet it's in the 4k range if they spec'd it based on the dynograph...
Old 05-08-2012, 12:39 PM
RudeG_v2.0
でたらめ検出器
RudeG_v2.0's Avatar
+1
Old 05-08-2012, 02:54 PM
  #38
Quamen
Quamen's Avatar
That would be crazy low! I run a 3,800 rpm in mine.
Old 05-08-2012, 03:22 PM
  #39
3kgtSL91
3kgtSL91's Avatar
you are probably right, i don't know, my tech was dealing with coan
Old 05-15-2012, 09:25 PM
  #40
Resmarted
Resmarted's Avatar
Good to see more info about this car!
Quick Reply: IPS Project G35 Sedan.... MONSTER! ver 2
