Finally Pulled the Trigger!!
Gang - Well, I FINALLY pulled the trigger on my Vortech'ed AEBS motor!! Brought my G over to John Isbell today & spent the afternoon with him ( @ Hooters! ) discussing things ranging from the engine, boost levels, drivetrain issues, etc. John's a REALLY knowledgeable & cool guy & I feel quite confident that we'll hit our power goals ( & then some!! ) with total reliability.
We figure his machinist will have the motor ready in 2 weeks so John'll be doing the Quaife & DSS axle work while taking measurements on the front end ( to see if we have room for the 4" FMIC + tranny cooler + Koyo + Aquamist tank ). Whew!! It'll be crowded behind the Stillen fascia.
John promises to post pics of the install on his website ( www. rabbidperformance.com ) so ya'll can watch the progress as I do.
Wish us luck!!
Gene
Wish us luck!!
Gene
Gene
My shop had no problem fitting the 4+12+31 Icevex IC . You just have to knotch the bumper brace on both sides . Getting the 3in pipe from the IC to the TB is a different story [ HARD ] Jonh has done it before . We mounted the tranny cooler on the passenger side . It filled the side hole on the KumuraZ bumper great .
Good Luck Bill
Good Luck Bill
U Know It!!
Bill - Yep, your name came up quite a bit today!! Feelin' the love, my friend!!?? John mentioned the placement of your A/T cooler & that'll probably be where mine goes. He wants to "display" the S/S 2.5 gallon methanol tank for the Aquamist up there so maybe it'll go on the other side - unless it blocks the air filter/Vortech assembly. Not sure how much room we'll have to play with since that Koyo is so thick. Might be pickin' your brain since U, Sung Nam & I seem to be the only Vortech fans here.
Meat - Without getting into the standard "S/C vs T/T" argument that seems to be forever ongoing here & over on G35Driver.com, the Vortech T-trim that Bill & I both have can support almost 800 hp so the engine isn't going to be limited by the Vortech, IMHO & in spite of what others say. However, IF it does seem to be the case then I'll be the first to admit it & then I'll be packing the Greddy kit ( yes, John & I have discussed that option ). Something ya'll don't know ( well, Bill might ) is that John has some "tricks" he's planning on using on my car that will bring the boost in earlier than on a standard Vortech & also be @ full boost ( 13-16# in my case ) sooner. He's also working on something that will make the S/C react as fast as a turbo ( by staying in boost more readily ) but I'm sworn to secrecy.
Tranny Concerns
As far as the trans goes, I have basically 2 options. According to Mark @ SGP, there should be some upgraded ( beefier ) clutch packs available for our trannies within the next 3 months. He feels that these will help our trannies to handle up to 800 hp. when coupled with their V/B & T/C mods.
#2 is probably the route that I'll be taking just because John ( my installer ) says that, IHO, having anything other than TOTAL control over the trans is defeating the purpose. Based on this, I'm looking into a GM 4L80E tranny from TCI. It's an electronic trans that will handle the same power range as the SGP ones but has the capability of having a TCM which will allow us to program the shift points, line pressure, etc. This is the control that John is looking for so we'll have to get creative with an adapter, custom driveshaft ( which I was upgrading to anyway ) & probably a paddle shift setup ( ala Ferrari ) .
This project ( like most I've been involved in over my lifetime ) has quickly snowballed into some serious $$ but what else is new!!
Gene
Gene
Thanks to All!!
Z - Actually it's a G35 coupe but the gang over at G35Driver.com aren't as hardcore as ya'll over here in terms of the performance arena so I figured I could pick up some suggestions/advice more readily over here!
Gotta give props to my friends Bill (Booger) & Dave O. for their advice & encouragement planning this project! Can't forget Brett (tig488) for his small contribution ( sold me his old Vortech!! ) & of course, Sharif for all the internal ( & expensive!! ) parts. But the biggest shout-out goes out to Gurgen. It's his old AEBS block that's the foundation for this build plus we've spent MANY nights on the phone comparing notes - thanks, my friend!!
Hopefully with everyone's continued support & encouragement we can get this animal where I/we want it!! Thanks again to ALL!!
Mean Gene
Mean Gene
Gene
Im amazed at the SGP VB . Along with the Edge Trq. Converter . The tranny Im sure will handle 500whp . The new , stronger clutch packs will take it much further . You might want to hold off looking into a tranny swap . If Vortech comes up with something for Derech at DSport [ better pulley system ] big hp will not be much of a problem at all for us SC guys . Trefling has already hit just under 500whp with his ATI Procharger at 14psi...on a MT6 [ DynoJet dyno ] ....will be watching your progress
Is It Ready Yet??
Originally Posted by rabbid
Yes it does!!!!!
Gene keep us posted
Gene keep us posted
Feelin' the love now, right, John??!!
Can't wait to see the results, I will be up there in terms of modifications pretty soon, I received my Icevex FMIC a few days ago and my new bumper will be going on Monday. I have to work on the new 3inch pipe next week to see if I can do what Bill did.
My T-trim is still not done so I am just sitting here waiting Hopefully I can get some ideas through your posts.
