GT Motorsports Short/Long Blocks
Old 12-26-2006, 02:41 PM
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Default GT Motorsports Short/Long Blocks
We are in the process of designing our site, so please bear with us. Until then, we will make the introduction of our products here.
Now: GT Motorsports® VQ35DE Short & Long Blocks
We offer four stages of short block upgrades. Here is what each features:
Stage 0:
Teardown inspection and cleaning of the core
Wiseco®/GTM® Extreme Duty pistons
Eagle® rods (with their alignment and resizing)
Mag and micro polishing of the crankshaft
Balancing of the rotating assembly
Rear main seal assembly
GTM® Race bearings (OEM bearings available)
ARP® 8740 main studs
Resurfacing (decking) of the block
Boring and honing of the block (with a torque plate)
Assembly of the short block
Stage 1:
Arias®/GTM® Extreme Duty or Wiseco®/GTM® Extreme Duty pistons
GTM® 4340 billet rods (with their alignment and resizing)
GTM® Race bearings (standard bearings available)
Stage 2:
Darton® M.I.D. sleeves (including installation)
Stages 3 & 4 (stroker packages):
GTM® 4340 billet crank (81.6mm[stock geometry], 87mm, or 90mm strokes)
ARP2000™ 12mm head studs with TimeSerts® (standard)
These are the 3.54/3.78/3.91L displacement “stroker” upgrades with a 96mm bore, 3.84/4.10/4.24L with 100mm bore for 81.6mm/87mm/90mm stroke cranks, respectively. Please refer to out prior write-up of these stroker upgrades for more information about the sleeving process and the crankshaft. 12mm head stud upgrade is standard, as noted above.
Pistons
Two piston types are available: Arias®/GTM® Extreme Duty, and the Wiseco®/GTM® Extreme Duty. Both are from zero-silicon aluminum forging, and are designed to have the highest heat and deformation resistance. They utilize buttons instead of spring locks, providing additional support. These GTM® pistons are the first to integrate a gas expansion groove between the two ring grooves, allowing additional small, yet critical, volume for gas expansion. The piston also incorporates a slightly taller than usual design, with longer skirts to minimize movement and vibration.
Rods
Designed in-house, and manufactured from 4340 billet chromoly steel. This material was chosen for this setup over titanium due to longevity, and over a regular forging due to the added strength. Each rod weights 500 grams, and is tested to withstand an equivalent of 2100ft-lb of torque on a 6cyl engine. This unique design allows for an unprecedented compression force/weight ratio, making it the most thoroughly designed and most suitable rod available for the VQ35DE.
Machining
All boring, decking, and sleeve installation is done with a Rottler® F65. The Rottler® F65 is a 4-axis, fully programmable CNC Boring Machine that yields unprecedented precision that far exceeds OEM tolerances. The honing is done with a separate Rottler® HP6A honing machine that uses special coolant as a lubricant instead of oil. The coolant is cooled as it circulates through the machine, keeping the temperatures at acceptable levels while still lubricating. This prevents overheating and warping/expansion of the honed surface/cylinder seen with oil based honing machines, yielding enhanced precision. Such precision is that much more critical when chrome rings are used, as is the case here. Chrome rings require this precision for proper break in, which helps them properly realize their superior strength and longevity relative to cast rings.
Oversize (12/14mm) head studs
This is an upgrade offered for every short block. The studs used are of the ARP2000™ material variety. The increased diameter of the 12mm studs and the appropriate ARP2000™ material make these studs the best choice in a hard-driven street car. If a full race setup is requested (not a street-driven car), we can upgrade further to a 14mm setup, which is far less forgiving and certainly not usually recommended. The less aggressive standard ARP 8740 studs are also available upon request for milder street applications, but are never recommended to our performance/track minded customers. ARP 8740/ARP2000™ oversize studs are $822 and $1269 option for 12mm and 14mm varieties, respectively, including parts and machining. Stage 3/4 short block upgrades include the ARP2000™ 12mm studs at no additional cost.
Nissan Pathfinder™ Cooling Modification
We can apply the cooling modification that utilizes upgraded cooling from the Nissan Pathfinder. The modification replaces the rear coolant return collector and adds an additional thermostat that opens at higher temperatures and raises the coolant outflow rate in demanding situation. This modification is offered for additional $200 for any of our block upgrade stages.
Long blocks
Combine any of the short block packages with the prior presented head packages for a complete long block:
GTM® Heads:
Stage 0: $1047
Stage 1: $1913
Stage 2: $3693
Stage 3: $4021
Stage 4: $5642
Full assembly (labor) of the long block, including all timing components and valve adjustments is offered for additional $700. We also offer the option (for the 03-04 model year engines) to use all new timing components, ensuring a complete renewal of the engine. Additionally, we can address the TSB issued by Nissan for noisy cam sprocket by replacing it with an updated one.
Availability:
Now
Turnaround Time:
2-4 weeks
Prices (GTM® short blocks):
Stage 0: $3297 (Wiseco pistons only)
Stage 1: $3617/$3860 (Wiseco/Arias pistons)
Stage 2: $6134/$6460 (Wiseco/Arias pistons)
Stage 3/4: $8919 (choice of Arias or Wiseco pistons)
Thank you.
Next: GT Motorsports® Spec Exedy® clutches
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Some pictures of the finished product
The pistons and rods
The machining: studs
The machining: boring
The machining: decking
The machining: honing
Pathfinder cooling modification:
Please let us know if there are any questions we can answer
Old 12-26-2006, 02:48 PM
failsafe306
failsafe306's Avatar
Those are some nice pictures
Old 12-26-2006, 03:06 PM
Beer Goggles
Beer Goggles's Avatar
Can you post information on what boost levels those are good for? I'm interested in getting my block built and looking at your stages I can't tell what is good for me.
I guess I should just stop in, makes things easier.
Old 12-26-2006, 03:13 PM
eagletanggreen
Got Track!!!!!
eagletanggreen's Avatar
Wow!
Old 12-26-2006, 03:16 PM
350zDCalb
builtZmotors
350zDCalb's Avatar
great work Sam! Anyone in Southern California should definately stop in and visit GTM, very impressive shop!
Vick781
Vick781's Avatar
nice pics!
Old 12-26-2006, 03:28 PM
roncfpz
roncfpz's Avatar
Very nice Sam. I'm certainly pleased with mine so far.
Old 12-26-2006, 03:38 PM
brooke
brooke's Avatar
I just bought a motor from Todd (built z motors) and they did the machine work,sleeves, and 5 angles head job.. Beautiful work... Thanks again Todd and GTM...
brooke
Old 12-26-2006, 03:41 PM
brooke
brooke's Avatar
! question though, I'm interested in the coolant mod you did on the motor?? Care to give any details on how too??
Old 12-26-2006, 03:59 PM
turismo
turismo's Avatar
Bravo!
Old 12-26-2006, 04:42 PM
G352NV
G352NV's Avatar
I would also like to know HP goal to what package.
Old 12-27-2006, 08:13 AM
BamBam
BamBam's Avatar
Great pics Sam... Very detailed as usual.. Man-oh-Man is that a lot of metal cut out during machining...
Can't wait....
Old 12-27-2006, 09:12 AM
BrianLG35C
BrianLG35C's Avatar
Thanks again Sam, for our recent phone conversation regarding your head packages. How much $ for the above option and what year of the VQ is this TSB referring to? How much to get a long block core included?
G352NV
G352NV's Avatar
GO BRIAN!!! Its about time bro. Do it!
Old 12-27-2006, 09:17 AM
superchargedg
Damn Noobs
superchargedg's Avatar
sweet!!!! awesome pic,s too.
Old 12-27-2006, 09:46 AM
Philthy
Boost Junkie
Philthy's Avatar
looking good Sam!
Old 12-27-2006, 09:58 AM
Kenk2
Professional
Kenk2's Avatar
Looks great Sam!! Great Prices too!
Old 12-27-2006, 11:15 AM
THE TECH
THE TECH's Avatar
Looks nice.
Old 12-27-2006, 12:54 PM
DSport G35
DSport G35's Avatar
Congratulations Sam, the blocks look great. Thank you again for putting up with my car. I appreciate all your hard work, support and putting up with my phone calls(Tony and Pablo too). I will be sending you an email shortly so I can get my sleeved block started.
DSport,
Derek
Quick Reply: GT Motorsports Short/Long Blocks
