A/C Refrigerant keeps blowing out of pressure release valve
Old May 1, 2024 | 09:58 PM
Z33.unknown's Avatar
Z33.unknown
Question A/C Refrigerant keeps blowing out of pressure release valve
A few days ago, I had my 350z idling and all of the sudden I looked like I was in a fast and furious movie with nos blowing out of my front end but I unfortunately don’t have nos. I checked for leaks with the UV light and only found it came out of the pressure valve. Yesterday (4/30/24) I refilled the system after testing for leaks, with found no leak so I put in 1.10 LBS of Freon in the system and the ac felt great after and blew ice cold, but today (5/1/2024) I was sitting in the drive through and it blew out again. I don’t want to keep refilling it and have it blowing out each time. Ac compressor is good, fan blow with the ac on, ac lines were replaced last year. Need help with this desert heat in Vegas.
thank you
Old May 26, 2024 | 04:07 PM
Mqj11221's Avatar
Mqj11221
Default Fix??
Did you get it fix im having the same problem however I replaced the high pressure line filled it twice and it popped twice.. this trial and error is getting expensive. I SEEN THE REPLACABLE O RINGS ON LINE HOWEVER MINES ARE NEW... AND SO IS MY CONDENSER... NEED HELP?
TheRedZed
Jul 2, 2018 08:22 AM
the_dood
Jul 8, 2015 04:15 PM
nick731
May 16, 2012 08:58 AM
boostintt
Oct 12, 2009 10:24 AM
manrey
Jan 7, 2004 02:10 PM
