Oil leak help (pic heavy)
Old 12-07-2016, 11:15 AM
Bmurray350z
Bmurray350z's Avatar
Default Oil leak help (pic heavy)
So I purchased a Z a couple weeks ago for a pretty good price. (thought so at least). I went to change the oil the following weekend and noticed what looked to be a lower oil pan leak. So i changed the gasket ad thought I had it fixed. Well a couple mornings after I noticed a very small puddle of oil under the car. So i finally got the car on a lift today and took some pictures.
First off, the car is an 04 6mt with 119k miles. Want to also mention i noticed the spark plug seals are leaking as well when changing the plugs last night.
Where i noticed it was most wet
Old 12-07-2016, 11:32 AM
Bmurray350z
Also wanted to ask what you guys think would cause what looks like oil grime to build up on the plenum area like this?
Old 12-07-2016, 12:59 PM
dcains
dcains's Avatar
I can't see where the leak is from the pics, but the grime on the plenum is just blowing up from below. Best bet is to get the engine completely clean, and then look for the source. You might even try some UV dye in the oil.
Old 12-07-2016, 02:16 PM
zakmartin
zakmartin's Avatar
This. After it's clean and you add the dye, let it leak for a couple days and then shine a UV light on it. You'll find the source quickly.
QuintonC (01-03-2017)
Old 12-07-2016, 03:15 PM
nizmo_0385
nizmo_0385's Avatar
pretty cool never heard of this b4
Old 12-07-2016, 03:49 PM
Italianjoe1
Italianjoe1's Avatar
The oil cooler, under the filter, has a gasket that leaks, which looks like yours is.
The oil on the back of the head is either the valve cover gasket, or the cam position sensor seals, which are very common VQ oil leak sources. Change both anyway if it's my car, neither is terribly expensive or a big deal. The cam sensor o-rings might be hard to find separate, but if you remove them and match up new ones you should be fine.
The oil on the top could be residue from spillage on oil changes (it doesn't evaporate so it collects dirt) or you could have an oil cap that isn't sealing well and allowing vapor to blow out onto the manifold. That one needs to be cleaned well and see where the source is.
The following 2 users liked this post by Italianjoe1:
jhc (12-08-2016), QuintonC (01-03-2017)
Old 12-07-2016, 04:01 PM
Bmurray350z
Appreciate the help guys. I'm trying to hunt down the part # for the oil filter housing gasket that Italianjoe1 mentioned.
As of now it's not leaving any puddle whatsoever. Even though it looks like it does in the pictures. I've had the undertray off all day and cardboard under the car after driving it and it hasn't dripped at all. Assuming it's a very small leak. And as hard as it is to get an accurate reading on the DE dipsticks, it does look like it's reading normal levels.
Old 12-07-2016, 04:15 PM
Bmurray350z
Found 2 oil filter o-ring parts. Anyone care to clarify which one I would need?
https://conceptzperformance.com/niss...11a_p_7832.php
https://conceptzperformance.com/nism...de_p_24065.php
Old 12-08-2016, 08:37 AM
Bak3rme
Bak3rme's Avatar
hey OP,
as stated above i would clean up all the oil with. I've had this issue and cleaned the mess by buying 3 or 4 cans of brake cleaner. Brake cleaner is the best degreaser IMO for metal parts. I'd spray the top of oil pan, sides of the block where you see oil and around the oil filter. brake cleaners cleans right up in seconds.
this is the oil cooler O ring you might be talking about. I would also check to make sure oil filter connector bolt is torqued to 36 ft/lbs or leaks can occur.
http://g35driver.com/forums/engine-d...er-o-ring.html
the gasket can be found here:
https://www.z1motorsports.com/oil-co...et-p-6351.html
ALSO i know for sure i have a leak behind the engine at the camshaft position sensor. those sensors have a gasket on them and over time they can degrade. I was able to see that leak when the car was on a lift looking directly up, nothing is needed to be removed to see that. Check your PCV to make sure its not clogged or defected also.
Old 12-08-2016, 10:22 AM
zakmartin
zakmartin's Avatar
If you ever need it done, I have a fully-equipped garage and I'm just up the street
Old 12-08-2016, 06:13 PM
nizmo_0385
nizmo_0385's Avatar
Hey thanks man i appreciate that!
Old 12-08-2016, 07:03 PM
Bmurray350z
Originally Posted by Bak3rme
hey OP,
happen to have a link to the cam sensor gaskets you mentioned?
Old 12-08-2016, 08:14 PM
Bak3rme
Bak3rme's Avatar
i haven't replaced it yet since its not a big leak. but i do not know where i could buy that gasket. when i do replace it i will jsut replace the whole cam sensor itself when it comes time in spring.
Old 12-15-2016, 05:38 PM
HCO_surfer
HCO_surfer's Avatar
With that much oil loss, how much is left in the motor? Check your dipstick religiously.
Old 12-15-2016, 06:24 PM
SmoothZ
Senior Super Moderator
SmoothZ's Avatar
Received 1,906 Likes on 1,354 Posts
Common problem with the plenum is that stupid oil cap rubber ring or whatever it's called. Someone must have taken the plenum off and when they reinstalled it, they didn't clear that rubber ring out of the way.
Does the car run rough?
The following 2 users liked this post by SmoothZ:
BluestreamDE (12-16-2016), QuintonC (01-03-2017)
Old 12-16-2016, 01:44 PM
Bmurray350z
Car runs absolutely perfect tbh. Threw a misfire and low input knock sensor code. Changed the plugs, noticed valve covers are leaking. But other than that, yeah runs fine.
I took the undertray off while i've been trying to find the main leak source and there hasn't been a drop of oil on the ground in the past week.
Old 10-30-2018, 08:02 PM
Evanryno55
Evanryno55's Avatar
Default The issue is most likely your valve cover gasket.
Attachment 383419
Attachment 383420
Attachment 383421
Attachment 383422
Attachment 383423
Attachment 383424
Old 09-24-2022, 05:29 PM
VQplatform
VQplatform's Avatar
I know this is an old thread but recently ran into this very exact issue. Could an upper oil pan look exactly like the one in the picture? If it was leaking from the camshaft o-ring why would the oil run toward the front of the engine along the sides?
