Question about my tune
Old 03-28-2017, 06:17 AM
Zokc
Zokc's Avatar
Default Question about my tune
He'll this is my first post on the forum. I had a quick question on my tune I recently got my 06 350z fitted with a single turbo. It's basically a turbonetics kit but I went with a precision 6262 turbo and uprev for tuning. I got tuned at 7.5psi on my wastegate spring and my numbers where lower than expected and my dyno looks rough[img]webkit-fake-url://5ef45e94-6b9e-49c1-846c-e652786fbf21/imagejpeg[/img]This is my tune from them along with my AFR aswell. It seems off to me but wanted some opinions.Thanks for the help!
Old 03-28-2017, 06:51 AM
bealljk
bealljk's Avatar
Check your link...
like anything in life, it's always good to get a second opinion...if there's another tuner in town go make an appointment...it may cost you money but a blown engine will cost more!!
Old 03-28-2017, 06:57 AM
iideadeyeii
iideadeyeii's Avatar
Uhhhh
Old 03-28-2017, 07:00 AM
Zokc
Zokc's Avatar
I think it should be posted now
Old 03-28-2017, 07:19 AM
iideadeyeii
I'm running a TN kit(godspeed) and have 295 whp , but 335 torque where yours peaks at around 3800rpm. The timings are probably very very conservative.
Old 03-28-2017, 07:22 AM
iideadeyeii
This is my graph. I think im at 7psi, but who knows with my emusa wastegate. cutout is set at 8-9psi I think and it doesn't hit it. My timing is only at 6.5-11.5 at full boost, so that's probably your problem too. Last time I switched to higher timing I fouled the stock plugs and had to revert and go cooler, but I never tried it again
Old 03-28-2017, 08:34 AM
Zokc
Zokc's Avatar
Okay the guy who tuned it for me said it was a conservative tune but I didn't know if he was just saying that cause he couldn't tune it properly that's good though. Does my AFR look okay? I don't understand why it drops off at 4K rpm and 5k rpm. Is that normal at all?
Old 03-28-2017, 12:50 PM
iideadeyeii
Looks like it's just be an error. You would notice if your AFR dropped to 10 since there would be a loss in power
If you can look at your timing map that might give you a better idea. 17-20 is what I'm going to be changing mine to at higher rpm's (aps tt timing map utec) if you want to take a look at it
Old 03-28-2017, 03:49 PM
bealljk
bealljk's Avatar
I'd take it to another tuner still...it would worry me why I went from 11.5-ish and dipped down to 10 : 1 in those areas with no explanation...
Old 03-29-2017, 03:54 AM
Zokc
Zokc's Avatar
Alright thanks for the input guys! Yeah I'm thinking about taking it somewhere else when it's all done. From what I've read online and compared to other dynos I should be making a lot more power that what i'm at.
Old 03-29-2017, 03:58 AM
Zokc
Zokc's Avatar
That and I asked the guy to tune it for e85 but he said I wouldn't need e85 cause i'm only at 7 psi. I didn't know they couldn't tune it for e85 being that low. I have a 7.5pound waste gate spring in it so didn't know if he got confused on that or if I had some boost leaks.
Old 03-29-2017, 04:01 AM
Zokc
Zokc's Avatar
Id love to see your map if you wouldn't mind posting it for me. Don't know if you have the timings for your map or not. If you do I'd love to see them to compare to mine. Seems like he just did 1 pull and didn't change much at all from there.
