idling with a haltech
Old Jun 23, 2008 | 02:00 AM
doomsdaydonkey's Avatar
doomsdaydonkey
Default idling with a haltech
howzit,
I am having an idling issue:
as soon as my car warms up slightly "a trip round the block" it starts knocking and clunking under the plenium when idling....
so whats changed, I got a haltech, great, but got info that it can only control rpm above 1500 or 2000. Spoke to some guys at injected and they said it may be a cam sprocket issue... thing is cam sprokets from nissan cost an absolute fortune...
so started playing around with the issue, when the solinoid is taken out of for the cams, idiling is smooth but i have no cam timing. as soon as its plugged in then rough idiling, rough like breaking the heads rough...
if anyone has had this issue before and changed their cam sprockets to get a solution please let me know. if any suggestions or ideas on how to solve this come through it will be appreciated. please note, other posts regarding idiling have very little info so am keen on providing a solution for all.
P.s. I can't change my idling rpm to above 1000, if I could somehow push thiis up i believe the oil pressure will be better, when looking at the timing chains when this noise occurs it looks like they are fighting one another, if i touch the throttle it goes away, oil pressure increases etc... so if anyone knows how to bump up the idle to 1500 for a quick fix that would be great...
cheers
ddd
Old Jun 23, 2008 | 08:42 AM
__jb's Avatar
__jb
Z + Rear Seat
You don't say what year your car is. Since you don't seem to be able to change the idle, my guess is that you have a revup. You'll need to use something like Uprev's Cipher or get a flash to change the idle speed.
I'd ask the person that initially tuned your Haltech to check the cam timing. If the cam sprockets were actually bad, you'd have more problems than this.
Old Jun 23, 2008 | 12:16 PM
gothchick's Avatar
gothchick
^^^ +1
It'd be bucking all over the place and you'd have a CEL for sure, if it even ran.
Old Jun 24, 2008 | 08:10 AM
UpRev's Avatar
UpRev
Just another point, but if you're thinking it has to do with oil pressure, and that raising the idle to fix it will work.... We can sell you a new motor when yours goes kaboom.
If you have an oil pressure issue patching it with more RPM is just going to make it worse. Replace the oil pump, replace the filter, switch to a better oil like the Torco brand SR-1 if you're NA (SR-5 if you're FI), do something to fix the oiling issue but don't patch that kind of problem.
Old Jun 24, 2008 | 08:15 AM
doomsdaydonkey
its a 2004 model, guys at haltech said it may b the cam sprocket. my tuner has organised a replacement off a blown motor 4 free... hope it works, gettin the parts on friday so will let u know, thanx
Old Jun 24, 2008 | 08:21 AM
UpRev's Avatar
UpRev
Nice! Hopefully thats the issue and not oil pressure related. Please note who your tuner is so that everyone knows he's willing to bend over backwards to support his customer.
Old Jun 25, 2008 | 09:55 AM
doomsdaydonkey
my tuner is in south africa, he blew up my first build and has had my car since january... i've paid 4 pistons,etc twice and been down 4 the past 7 months... no idle issues on the first build even after a bent crank and 3 pistons gone....
Old Jun 25, 2008 | 10:14 AM
UpRev's Avatar
UpRev
Ship the car here, we'll complete it and tune it and then ship it back. It may be cheaper and easier to do that. I know Boost Logic does that kind of service often for the same reasons on the Supras.
Old Jun 25, 2008 | 10:32 AM
Hoooper's Avatar
Hoooper
just a note, try to use for and not 4, that post took me like 15 attempts to understand. was wondering why you had bought 4 pistons, what 4 pistons etc meant and why say 4 of the past 7 months. i get it now, just thought you might wanna look into that for the future. you might wanna look for a new tuner if hes blowing your builds like that
Old Jun 26, 2008 | 08:23 PM
overZealous1's Avatar
overZealous1
i would be really questionable with the engine builder and tuner. there is some o-rings and seals that need to be installed upon motor assembly, and if they are forgotten, would have the issues with the cam sprockets like you are saying. not an easy fix and the front timing covers need to come off. you can pull the intake cam covers though and check there first though and keep your fingers crossed to find a missing seal there.
Old Jun 26, 2008 | 08:26 PM
mikez97's Avatar
mikez97
Ship it to Performance factory
Mine has been idling just like stock =]
Old Jul 15, 2008 | 06:54 AM
doomsdaydonkey
HI,
this was an issue with the cam sprocket... it was replaced and the problem went away
cheers
ddd
Old Jul 15, 2008 | 07:01 AM
Jay'Z's Avatar
Jay'Z
How much did the fix cost you btw?
Old Jul 15, 2008 | 09:02 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
HI,
cheers
ddd
Glad to hear you got it taken care of
Old Jul 17, 2008 | 02:04 AM
doomsdaydonkey
thanks for the advice hal and co...
the fix cost me about 250$, I got an old intake cam sprocket off an engine that had blown, "very lucky" Nissan want to charge over 1000$ for an intake cam sprocket...
cool
DDD
liqalu04
Jan 2, 2022 12:58 PM
