Unofficial Enkei Wheels Thread
#2203
Im going to buy new set of tires for the stockies and see if theres any unusual wear on them.
But ive read when people go with wider rims camber arms usually help keep things in spec.
#2204
^^^ It's actually people that lower their cars install suspension arms to keep their alignment in spec, the width of the wheels has nothing to do with camber/toe/caster/etc. at stock height.
You didn't mention if the Z you purchased had coilovers/lowering springs? Z's have slight negative camber from factory could explain the wear from those sh*tty rimz.
#2205
also i dunno what year you have but some of the earlier models have feathering issues as well.
#2206
#2207
No longer an Enkei owner so this is my adioś Sold them last night. Trying to consolidate and get one set of wheels. Advans for sale...
Specs edit: 18x10.5 +15 F & 18x10.5 -10 R 265/35/18 Hankook V12's. Sad part is I have a brand new set of 285/35/18 RS3 in the garage for these...
Chris
Chris
#2210
something is up with your sizing...
the only offset they make in a 18x9.5 is a +38.... which looks like what you have based on how the wheels are sitting in the pics. a +12 on a 9.5" would be much more flush than what you have there.
personally I'd get a 15-20mm spacer to run in the rear.
all that said, still a nice choice in wheel
#2220
