FS: Enkei RPF-1 black (2) 18x10.5 +15, (2)18x9.5 (+45) w Tires
on
Selling my rear rpf1's. They have around 4000 miles on them and are extremely light at only 19.04lbs!! They are enkie factory black, no plasti dip or powder coating that I had done. However for $85 a wheel I can have them PC colored however you want from IPS in Columbus. They are of course 18x10.5 +15 and 5x114.5. You will need new lug nuts for them! The factory washer style doesn't work. You need normal acorn style. Also you will need hub centric rings for them. The OEM hub is 66mm and these wheels like almost all Enkeis are 73mm so they fit many vehicals. I use both these part numbers for mine.
http://www.summitracing.com/parts/gor-21123bc/overview/. Steel! Not aluminium.
http://www.summitracing.com/parts/gor-73-6606/overview/
Buyer pays shipping to lower 48 for $27.50 a wheel from the USPS. $39.95 to HI and AK. $625 OBO for the rears
Selling my front rpf1's with HTZ Z3 tires in 255/40/18. They both have about 4000 miles, tread is 9.5/32nds, that's 95% tread left. The wheels are 18x9.5 +45 and are only 17.4lbs!! They have no curb rash and are plasti dipped black over the factory silver color. Under the dip they are mint condition since the dip is still in perfect shape. However for $85 a wheel I can have them PC colored however you want from IPS in Columbus.
For these to fit my sport package I needed a 20mm spacer. I'm not sure about a none sport model. You will need new lug nuts for them! The factory washer style doesn't work. You need normal acorn style. Also you will need hub centric rings for them. The OEM hub is 66mm and these wheels like almost all Enkeis are 73mm so they fit many vehicals. I use both these part numbers for mine.
Buyer pays shipping and paypal. Asking $850 for the fronts with tires.
on
Well the fronts a 9.5" and rears a 10.5" so you can't just look at the offset and equal them out. I needed a 20mm for the front to clear the akebono brakes. If you have base brakes you might get away from something smaller or nothing. I test fitted a 15mm spacer and it worked but it was a stud replacement spacer and I wanted a bolt on so I went with the 20mm. A 30mm would push it pretty far out. If you have lots of camber it will probably look ok though. For both I'm asking $1275. Let me know.
