Gas gauge malfunction
Old May 12, 2006 | 01:16 AM
JoeyFyed's Avatar
JoeyFyed
Default Gas gauge malfunction
So, these past two days i have been puttin 10$ of gas a day. Its get to about a quarter tank, but after about 3-4 miles it reads empty, jumps from 50ish miles to empty to 13 and less. Im forced to restart my car to get the gauge back up... any ideas?
Old May 12, 2006 | 01:24 AM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Faulty gauge, sender or wire. Contact your dealer.
Old May 12, 2006 | 01:29 AM
JoeyFyed's Avatar
JoeyFyed
if thats true, i wont have time to make it to the dealer for a few days. Is the car safe to be driven in the meantime?
Old May 12, 2006 | 02:29 AM
abstrakt's Avatar
abstrakt
yes, its safe to be driven
Old May 12, 2006 | 02:41 AM
imseksy's Avatar
imseksy
man read my post about my DTE going from 57 to 0 in 5 seconds
Old May 12, 2006 | 09:50 AM
frizille's Avatar
frizille
I had a similar problem with mine. I'd fill the tank but still show 3/4 full on guage. After restarting the car 2-3 times it would magically show full. As I drove and used the gas up the guage would fluctuate +/- 1/8th of a tank. I took it over to the dealer under warranty (its an 04.5) and it turned out to be the "fuel sending unit" in the gas tank. According to the dealer there are 2, 1 in the tank and 1 in/around then engine. The one nearest the fuel tank was the one that was bad on mine.
Old May 12, 2006 | 11:24 AM
Fletch69z's Avatar
Fletch69z
Dealership...
Old May 12, 2006 | 12:46 PM
JoeyFyed's Avatar
JoeyFyed
So, to make matters easier with my dealership. Should i just explain the problem, or is there a TSB for this... its an 06 btw, at least i dont have tire feathering tho. =]
Old May 13, 2006 | 07:24 AM
Ztalker's Avatar
Ztalker
nissan fuel sending units are prone to malfunctions.
Old May 13, 2006 | 08:35 AM
Mathys's Avatar
Mathys
Think the warranty should cover it. Fuel sending units should last longer then a couple of months.
Old May 13, 2006 | 03:44 PM
JoeyFyed's Avatar
JoeyFyed
Im pretty sure, im taking it to performance nissan which is a 15 min drive from my house... i only got about 5500k miles on my Z
Old May 13, 2006 | 08:59 PM
Ztalker's Avatar
Ztalker
guess what....my pathfinder and new Armada both had defective fuel sending units replaced under warranty..
Old Feb 17, 2009 | 05:27 AM
JasonZ-YA's Avatar
JasonZ-YA
does anyone have a picture of where this fuel sending unit is located....
< --- im off to dig through the factory service manual to try and find it..
-J
Old Feb 17, 2009 | 05:45 AM
trodis's Avatar
trodis
Common problem with all Zs. There are threads related to this. I had to bring mine down to have it fixed and its an 07
Old Feb 17, 2009 | 06:35 AM
JEKL's Avatar
JEKL
I just had mine replaced yesterday on my '06 with 17k miles and it was all under warranty. I didn't have your symptoms, but the service tech asked me about the 3/4 full tank part and said that was another typical problem with the fuel sending unit.
It does not hurt the cars performance at all. Just take it to the dealership, enough said.
Old Feb 17, 2009 | 07:47 AM
jt14894's Avatar
jt14894
My fuel gauge has been doing the same thing for at least a two years, but I didn't really think much of it. I guess I need to get it fixed.
By the way, which warranty is that covered?
My Z is a 2003 with 53,600+ miles. I assume if it's covered under the basic 3/36K I'm out of luck..
JT
Old Feb 17, 2009 | 07:51 AM
terrasmak's Avatar
why not just fill it ?? Why just $10 a day
Old Feb 17, 2009 | 09:11 AM
Edg_R's Avatar
Edg_R
same problem here
Old Feb 17, 2009 | 01:59 PM
my350isblack's Avatar
my350isblack
does it read 0 after turning hard, like getting on or off a highway? mine only does that if i have a quarter tank and turn fast
Old Mar 10, 2009 | 09:16 PM
ZTMYDUST's Avatar
ZTMYDUST
My '04 with 46k does this. When I fill the tank the gauge goes right to full as it should but sometimes only goes half way. I can have half a tank and it will be on E with the light on. I usually just run it to around 200 miles and fill it back up. Even under heavy driving i've never ran out going 200 miles.
I think my sending unit it floating around or something.
