Wheel offset help
on
Wheel offset help
I was planning on getting RH J8, but they are on back order. I need to get wheels in less than 1 week, so i ve decide im going to get different wheels. I was just concerened about the specifications the wheels should have for the Z. The size is deffenetly 19" and with lip.
*I am getting hoppefully stagered, if not what would the width have to be?
- If staggered ~19"x9 F and 19"x10 R
- If not stagered is it possible for the Z?
*What does the offset have to be?
Every piece of help is appreciated, Thank You.
Performance Nissan
Performance Nissan
on
It depends on the wheel... and if you have brembo's or not...
If you have Brembo's you want a high-pad wheel...
19x9 you will want an offset between 22 and 27mm
19x10 you will want an offset between 22 and 30mm
We have 19" wheels instock for the 350z...
