Heater
Everytime I turn on my heater it only works blowing hot air when im driving, but when I stop like at a stop light it starts blowing cold air until I go again. Anyone else with this problem?
I have the EXACT problem. I have no idea what it it. It seems to be related to engine RPM. When you stomp on it, the heat comes on. If you let it idle, it goes almost cold.
After 10-15 minutes of driving, it seems okay and returns to normal operation.
Damn, do I have to do everything? Click below:
https://my350z.com/forum/showthread....threadid=63927
Turns out that was not the valve in question. Since I could not find given valve, I simply opened radiator cap before I started the car (it was COLD). There was a bubble of air, and then some coolant. I put the cap back on and tested the car and it seems to work better now. Still has a small amount of air somewhere, so I'll probably repeat the process later.
DISCLAIMER: Do not open radiator cap if car is running, or hot.
"do you have the AC light on or do you press it off?
keep it on and it stays hot all the time..
atleast from my experience...
__________________
Really?? Keeping the AC light on will stabilize the heating element? WoW learn something new all the time. Seeing that the AC light comes on automatically, one less thing to do in startup.
Sully
__________________
Sully
Arash
May 4, 2004 10:54 AM
