Ceramic Disk pads vs Hawks HPS. Which would be better?
Old Dec 8, 2004 | 03:24 PM
Naples176's Avatar
Naples176
Question Ceramic Disk pads vs Hawks HPS. Which would be better?
I am going to replace the stock front pads with either a ceramic pad (from TireRack) or HPS but do not know which would be better. My 350ZR is a daily driver and want to be able to see the front wheels for more than one day after I wash the car! I am looking for replacements pads that will brake at least as well as the stock pads and will be as quiet, but have a LOT LESS brake dust! Any thoughts will be appreciated.
Old Dec 8, 2004 | 10:41 PM
ssk0771's Avatar
ssk0771
From what I know, ceremic pads are quiter and are easier on the rotors with good bite. I use to have Satisfied Ceremic Pads on my previous Z before I switched to Hawk HPS. From my experiance, Satisfied Ceremic was pretty good. I am going to try Akebono or Hawk Ceremic nextime too. I like Hawk HPS because it has very low brake dust but as for the bite, its about same as stock. I am greatful that I don't have any brake noise but I saw lots of people who are complainting about Hawk HPS because of the brake noise. If you decide to try the Ceremic, please keep us posted.
Old Dec 9, 2004 | 07:46 AM
rclab1's Avatar
rclab1
Default Hawk HPS
Get the HPS ,
just break em in properly and it wont squeak
plus tell the technician (or you if you install yourself)
to put extra grease.....on the pads....
It is 10x better than the OEM pads in terms of
No (hardly) any Break Dust.....
100% improvement in my opinion as a daily driver....
Old Dec 9, 2004 | 09:31 AM
Naples176's Avatar
Naples176
Is it okay to just change the front pads or should I change both? I was thinking of changing only the front as they do most of the braking.
Old Dec 9, 2004 | 10:33 AM
roydiculous's Avatar
roydiculous
I've done just the front and are very satisfied... althought when it does dust, isn't not gunmetal, it's this brown dust . I'd say save your $$ and just do the front.
Old Dec 9, 2004 | 01:40 PM
RedBird's Avatar
RedBird
I had a problem with brake dust on the drivers side front wheel, but after I took it in for regular service which included a brake adjustment, I no longer have the problem.
Old Dec 9, 2004 | 02:02 PM
DaddyPhatSaks's Avatar
DaddyPhatSaks
I changed my fronts to EBC greenstuff....Hardly no dust, no squeeks or anything. Well worth $60 buks!
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
