Dreaming of NISMO...
Old Jun 19, 2002 | 05:54 AM
kevintari's Avatar
kevintari
Default Dreaming of NISMO...
So I'm thinking (because I have nothing better to do until the end of August now)...let's say the 0-60 is around 5.5. Nismo is going to have to provide some pretty decent performance improvements to warrant the extra expense...think it'll be easy to get the Z under 5.0 with their stuff?
Yes, I know it's all just a guessing game, but I'm bored.
Old Jun 19, 2002 | 06:11 AM
c350z's Avatar
c350z
Well no one knows for sure that it won't be under 5.5 as is. Also it depends on the skill of the driver. But I am sure that no matter what the 0-60 time is, that there will be tons of aftermarket goodies to help everyone live out their fast and the furious fantasies.
Old Jun 19, 2002 | 06:18 AM
azmo's Avatar
azmo
Hey JmanZ, its seems like youre DYING to tell us the performance numbers man. It must be sooooo hard keeping them to yourself all this time. Dont u just want to spill it? Just playing around. I respect the fact that you gave them youre word. Cant wait till july 3rd..or till you american pre-orderers get the surprise in the mail. Im pretty sure us canadian pre-orderers aint getting jack in the mail.
Old Jun 19, 2002 | 06:25 AM
azmo's Avatar
azmo
A canadian pre-orderer posted on zcar.com that he or she called nissan canada and asked them about the mailing. Nissan Canada stated that we wont be getting one. He or she then went on to ask when the specs and performance numbers would be released. Nissan Canada stated July 3rd. Therefore im going on the limb and assuming that we are not getting anything in the mail.
Old Jun 19, 2002 | 09:56 AM
kevintari's Avatar
kevintari
Originally posted by JmanZ
Well, you're right that it does come down to the skills of the driver, but... there are some that know for sure as to whether or not it'll be under 5.5. haha... I'm one of them.
-j-
...so can you say if it's *well* under 5.5?
Old Jun 19, 2002 | 09:59 AM
nizl's Avatar
nizl
Originally posted by VQracer
I believe that every pre-order participant will get it in the mail. Why would Nissan leave out Canada?
Dude, as EVERYBODY knows, Canadians aren't real people.
Old Jun 19, 2002 | 11:50 AM
SirZaLot's Avatar
SirZaLot
Hey, I don't get it
BTW, what is ECU? And what does it do?
Old Jun 19, 2002 | 12:15 PM
dc350z's Avatar
dc350z
Smile
I measures the sound coming from the muffler bearings.
Old Jun 19, 2002 | 04:36 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
An ECU, if I understand it correctly, is a computer chip added to the car that controls how the engine runs (fuel, air intake etc.) That is my rudimentary understanding of it. OK, now will the REAL car guys please explain it for him.
Old Jun 19, 2002 | 04:57 PM
bobbyz's Avatar
bobbyz
As a canadian with a Z on the way, I must say I am pissed about the lack of info. My dealer claims they have not gotten the accessory list of the Z yet where you guys down south are stating that you already have the parts microfiche. All I want is a damn rear spoiler for my non-track . We canadians do not even know what our car comes with. We were not given the option of floor mats, trunk mats, splash guards or stainless door sills. So do we get them or not? No one can tell me. HOWEVER, we did pay a lot less for the car then the US so if one of the ways they are saving money is by no mailers, then so be it and we should all thank Jmanz for relaying the info that we are not getting from Nissan.
Old Jun 19, 2002 | 05:04 PM
350zhawaii's Avatar
350zhawaii
don't feel too bad in Canada....people in Hawaii , we won't get any "special mail" either...so I'll be counting on all here to post the good news. Thanks
Old Jun 19, 2002 | 06:24 PM
LS350Z's Avatar
LS350Z
Charter Member #56
ECU - Bassically like Dr Bonz said, the ECU is the main computer in your car. The ECU works basically as follows.
1. Inputs: ECUs recieve inputs from sensors in your engine, these sensors include things like the Intake Air Temperature (IAC), Intake Manifold Pressure, throttle position, oxegen sensor (o2). With these data points it then controls the amount of fuel, through the injectors, to run the engine smoothly and reliably. The input data points are used in a matrix to determine the 'so-called best' A/F ratio (Air/Fuel ratio) for the engine to run.
Typically manufactures will run the A/F mixture slightly rich to keep the engine cooler, running better, and safer. If the engine is run to lean it creates a lot of heat and things like detonation (pre-ignition), can occure.
An ECU upgrade will alter the programing of the stock ECU to give better performance. This, on an OBDII equiped NA motor, can sometimes give gains in HP and sometimes take power away depending on what else is done to the vehicle.
Things like the APEXi S-AFC is an air/fuel piggy back computer that tricks the ecu into seeing a different reading then the motors actually putting out. These are adjustable meaning with a good low-pass O2 sensor and some dyno time you can easily tune your engine across the whole power band at different intervals, ensuring your car is always running at peak performance.
Old Jun 19, 2002 | 06:38 PM
Jill's Avatar
Jill
Thanks for the explanation Kevin.
Old Jun 19, 2002 | 08:42 PM
azmo's Avatar
azmo
I think that the 0-60 is for sure going to be under 5.5 secs..otherwise Jmanz wouldnt be soo excited to tell us. I anlayzed his posts and ive come to the conlcusion that hes DAMN excited!! JmanZ i hope u just were not in a very good mood when u were writing those posts.
Old Jun 19, 2002 | 08:54 PM
Phi-1002-'s Avatar
Phi-1002-
A little more info about rich/lean AF ratios...
Running the engine lean produces higher combustion chamber fluid temperatures. In addition, because the mixture is low on fuel relative to the air supply there's more free roaming oxygen scavenging around in the exhaust. The high temps combined with large amounts of unused O2 result in high NOx (nitrogen oxides) in the emissions. This is one of the EPA measured emissions that is BAD for the environment. So, they run the engines a little rich.
Running to rich on the other hand produces smoke in the exhaust but there's a delicate balance that works pretty good especially with the vehicles' catalytic converters. That's why they run a little rich instead of lean.
Old Jun 20, 2002 | 01:29 AM
CaneZMD's Avatar
CaneZMD
Did everyone miss that? I know it was a little bit of flame, but "Muffler Bearings"?? That's really funny!! I'm laughin out loud right now.
bcoffee20
Nov 19, 2015 06:39 PM
davidm350
Oct 31, 2015 02:28 PM
SpartanZ32
Oct 22, 2015 09:36 AM
35th4me
Sep 13, 2015 05:14 PM
