ground clearance question..
Old Nov 12, 2002 | 11:04 AM
wise_1's Avatar
wise_1
Default ground clearance question..
i know that 350z is pretty low and i have these massive speed bumps in my work parkinglot... they are HUGE and they are double speed bumps.... (very hellish...)
so before the body-kits, did anyone have trouble going over regular-size speed bumps? or does aero-kit give lower clearance??
please give me some inputs..
thanks...
Old Nov 12, 2002 | 11:17 AM
mydogscool's Avatar
mydogscool
Very slowwwwwllllllyyyyyyy........., if the bumps are over 4.5" tall, then now way.
Old Nov 12, 2002 | 11:20 AM
RobJames's Avatar
RobJames
You aren't going to have any problem. Don't worry about it. I have a 10 inch incline at the beginning of my driveway and I can go straight at it and not hit. The tires are so close the front bumper that the bumper moves up with the tires very well. The bump is going to have to 5 inches high or so to scrape the front lip and you have another inch or inch and a half before the bottom of the bumper. IMO
Old Nov 12, 2002 | 11:43 AM
ares's Avatar
ares
Veteran
clearence on the Z is 4.7inches, end of story. however I would bet money that the lowest point of the car(where clearance is measured) is the diff in the back, meaning the tires will raise the car over the bump. but I wouldnt expect the next lowest spot(front bumper perhaps) to be too much higher. maybe 5-5.5"?
so basicly, you should be ok, cause that would mean you would need a 5inch bump that the car can rest its wheels around, like a speed bump, not a speed hump where the back wheels are on the bump before the front wheels go off the hump.
hope this helps somwhat, my final answer is measure them, vertical hieght, assuming they are narrow bumps. then if its less than maybe 5 inches your ok. just go REAL slow over them so the car doesnt dip down on the suspension when coming off them.
416blueZ
Jun 11, 2024 10:56 AM
hulkout
Apr 28, 2017 09:00 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
cashmoney03
Sep 27, 2015 05:24 PM
416blueZ
Sep 24, 2015 02:11 PM
