TRASH MY CAR, Advice needed.
Old Feb 20, 2005 | 04:51 PM
kelvin1704's Avatar
kelvin1704
Default TRASH MY CAR, Advice needed.
BAD NEWS!
Just got it from the Service Representative.
My car, appears to have to change:
a) Master Pump
b) Sleeve Pump Clutch
c) Clutch Assembly (Maybe need to change cause have not take it out to check, but highly possible damage.
I ask what cause this, he said got to check with the mechanic.
Can anyone tell me what cause it to happen?????? isn't my car suppose to be track ready????
and how much does it cost to replace those stuff?
Old Feb 20, 2005 | 05:08 PM
7744's Avatar
7744
I'm confused. Are they telling you that you need to replace the stuff to take your car to a track? Or have those items gone bad?
Old Feb 20, 2005 | 06:40 PM
330R's Avatar
330R
Well the 350Z has a certain level of track capability, but that doesn't mean it's a purpose-built track car.
Even in a track car, if you abuse the clutch, it can wear out.
Old Feb 20, 2005 | 07:40 PM
kelvin1704's Avatar
kelvin1704
They are telling me that those stuff are confirm bad except the Clutch Assembly but they highly suspect its damage.
Basically, I want to know
a) Since its already bad, i have to accept it. What kind of replacement i should get for the above stated stuff so that I can go tracking again without worries.
b) What actually cause it? Temperature? Some said I might have abuse the clucth, but I don't seems I did other than just one occassion which is possible but if its that case, then the car is built being quite fragile.
c) Is 350z suitale for tracking? or its because of our hot weather here?
Old Feb 20, 2005 | 08:10 PM
Sensation350Z's Avatar
Sensation350Z
might seem like a stupid question but what transmission are you using? also did you get the track version of the z?
Old Feb 20, 2005 | 10:28 PM
FairladyZ's Avatar
FairladyZ
It has a clutch so it has to be a 6spd. Sounds like you track your car so you are slipping your clutch, high rev launches, etc. Yeah you are gonna ware it out quick.
Your best bet is to get a better clutch and flywheel. Go aftermarket, cause stock parts are going to be just as expensive.
Old Feb 21, 2005 | 01:29 AM
kelvin1704's Avatar
kelvin1704
I have been told this is the track version as it comes with Brembo brake and spoiler.
This is an Manual 6 gear...
Boss System
Electronic adjustable driver seat with heater.
____________________________________________________
Aftermarket? Can someone recommend me brands and stuff..... i am really blur with all these..
Old Feb 21, 2005 | 03:58 AM
Z BOY's Avatar
Z BOY
use the forum search button, and educate yourself.
Old Feb 21, 2005 | 04:27 AM
FairladyZ's Avatar
FairladyZ
Boss System
How hard do you drive your car?
Old Feb 21, 2005 | 07:24 AM
mdacko's Avatar
mdacko
theres tons of options for aftermarket clutches and flywheels
http://performancenissanparts.com/ca...th=153_175_372
good place to start
Old Feb 21, 2005 | 07:26 AM
mdacko's Avatar
mdacko
http://www.hopupracing.com/drivetrain.html
more options
Old Feb 21, 2005 | 11:47 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
I thought the BOSE only came on the touring???
Old Feb 21, 2005 | 12:08 PM
FairladyZ's Avatar
FairladyZ
he is from Malaysia.
Old Feb 21, 2005 | 12:14 PM
zownz's Avatar
zownz
it does...the track does not come with heated leather seats..the seats are cloth...what can happen is that your clutch master cylnder or slave cylnder went bad...or maybe was low on oil..meaning..no oil for the throw out bearing..no oil causes the bearing 2 heat up due to friction..mess up and ur clutch pedal will either fall in..or wont work @ all..your clutch disc does not have 2 be bad..
Old Feb 21, 2005 | 02:11 PM
330R's Avatar
330R
This is circuit racing, correct? Not drag racing?
Old Feb 21, 2005 | 07:20 PM
kelvin1704's Avatar
kelvin1704
I did circuit racing.
Like normal, i go full trottle after every sharp turn. But never has the opportunity to go top speed of the car.
Old Feb 24, 2005 | 04:53 PM
kelvin1704's Avatar
kelvin1704
Alright, for news.
Firstly they tell me I need to replace;
a) Master Pump
b) Clutch Sleeve
c) Clutch Assembly
Now they sent me a quatation with all different names...
a) Clutch Cover
b) Clutch Racing Plate
c) Clutch Bearing
d) Top Clutch Pump
e) Bottom Clutch Pump
Can someone bring me to light?????
they say all this are original from Nissan
Will cost me around RM4250 including a workmanship of RM1100.00
1US dollar = RM3.80
Old Feb 25, 2005 | 03:47 AM
kelvin1704's Avatar
kelvin1704
nyone
Old Feb 25, 2005 | 09:54 AM
MA4's Avatar
MA4
is the car out of warranty or something?
Old Feb 25, 2005 | 10:07 AM
The Brickyard Rat's Avatar
The Brickyard Rat
What your describing sounds like a combination of, what is in the USA, a Track & Touring model.
It sounds like you may have woren some "stuff" out on on a track; if so, I doubt warrenty would cover it.
What you probably need to know is if you should replace the parts with Nissan parts or an after-market company. (I'm not the one to answer the latter questions).
